YellowAircraft
Joined: 1/5/2002 From: San Diego, CA, USA Status: offline
Well, The new kit has some refinements that will help ease up the workload a bit. The one I'm most excited about is the use of carbon under the wing and tail skins. Not because the wings and tails weren't strong enough before, but because now I'm not gonna have to carve-and-sand-to-shape the balsa blocks that capture the stabilator shafts to mate up with the balsa stab sheeting. It was a pain because those balsa blocks are pretty hard balsa while the sheeting is just sheeting. On the new stabs, one has only to get the block good enough to fit in there pretty well, then glue it. It's possible that this bird may end up being powered by two P-80+ engines. My thought is that with the omission of that windsock (oops, I mean single inlet) up front, the frontal airframe drag will be reduced substantially. Also, my understanding is that losses are much less with straight pipes than with split pipes. Thoughts?
_____________________________
Yellow Aircraft, JetCat Engines, Skymaster ARF+ and Turn Key Jets www.cyctheatre.com
