t_burley
CA, USA Status: offline
PCM 109 by far! it is not really a beginners kit for sure the wings, and tail feathers are foam cores, you sheet them and cut out for flaps/ailerons and elevators. I have been working on mine off and on since December of last year. it builds into a GREAT 109! it all depends on the detail you want to add, as to how long it takes to build. there is ALOT of work to do in building in, even though it is a glass fuse, and foam wings, you still need to do alot of planning, and measuring etc. to get it all dialed in correctly. I will hopefully be adding paint next month? we'll see, the more I build, the more detail I add todd
_____________________________
Todd Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin customer
