RE: Subaru Impreza WRC 1/10 Bycmo    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Subaru Impreza WRC 1/10 Bycmo
Page: <<   < prev  59 60 61 62 [63] 64 65 66 67 68   next >   >>
Login
RE: Subaru Impreza WRC 1/10 Bycmo - 1/5/2013 11:11 PM
dust75
Score: 100
Last Login: 5/8/2013
Status: offline
hi ian
here is a link to the last truck meet we had last year if you scroll down you will see the new/old fire engine
http://scaletrucks.bb3host.com/viewtopic.php?f=18&t=2077
ita a robbe airport fire engine its meant to be one of the first rc trucks to be made
it has lights head/back/indicators/reverse lights and it also has flashing blue lights
(new leds from gt power they would look awesome in a bycmo shell (link http://www.ebay.co.uk/itm/GT-POWER-RC-Car-LED-Lighting-System-2-0-1-10-Truck-Drift-On-Road-Yokomo-Tamiya-/110997323032?pt=UK_ToysGames_RadioControlled_JN&hash=item19d7f4bd18 look at the price)) and a sound system for the siren
Hide Signatures
(in reply to Ian78)
       Post #: 1551
RE: Subaru Impreza WRC 1/10 Bycmo - 1/5/2013 11:45 PM
Ian78
Score: 100
Last Login: 5/10/2013
Status: offline
 The esc just plugs into your standard reciever and then the wires go to your motor, very easy.
Dus was the one who reccomended the hub conversion to me when I first joined.
Bycmo run 10mm hex instead of 12mm hex.
You need to fit 12mm hubs.
Will find a link on ebay for you Steve.
Basically these
http://www.ebay.co.uk/itm/12mm-Drive-Hex-Hub-Wheel-Aluminium-Yellow-x-4-with-Pins-/330451510329?pt=UK_ToysGames_RadioControlled_JN&hash=item4cf071e439
Hide Signatures
(in reply to dust75)
       Post #: 1552
RE: Subaru Impreza WRC 1/10 Bycmo - 1/5/2013 11:56 PM
Ian78
Score: 100
Status: offline
The Fire truck with all the wheels dus?
Doesn't look that old to be honest...
Steve, been a while since I fitted them but just remembered that you need to file a small piece of plastic from the plug on the esc before fitting it into the reciever.
Small file and about 5 mins work.
Hide Signatures
(in reply to Ian78)
       Post #: 1553
RE: Subaru Impreza WRC 1/10 Bycmo - 1/6/2013 1:36 PM
dust75
Score: 100
Status: offline
yeah the one with all the wheels
that says fire brigade on the side
its about 30 years old
the water cannon on the top works
moves left and right up and down and sprays water
Hide Signatures
(in reply to Ian78)
       Post #: 1554
RE: Subaru Impreza WRC 1/10 Bycmo - 1/6/2013 2:00 PM
Ian78
Score: 100
Status: offline
quote:
ORIGINAL: dust75that says fire brigade on the side
  Kinda gave it away haha.......
My post was after a few beers to be fair.
Hide Signatures
       Post #: 1555
RE: Subaru Impreza WRC 1/10 Bycmo - 1/6/2013 8:53 PM
dust75
Score: 100
Status: offline
did you look at the link for the lights what do you think?
Hide Signatures
(in reply to Ian78)
       Post #: 1556
RE: Subaru Impreza WRC 1/10 Bycmo - 1/6/2013 9:19 PM
Ian78
Score: 100
Status: offline
 Lighting system looks awesome.
Hide Signatures
       Post #: 1557
RE: Subaru Impreza WRC 1/10 Bycmo - 1/10/2013 5:28 PM
Daviejones
Score: 100
Last Login: 4/11/2013
Status: offline
Thanks again for the info both , I've just bought a new sport tune tamiya motor for it and a new esc , I just hope I can get it all to work
Hide Signatures
(in reply to Ian78)
       Post #: 1558
RE: Subaru Impreza WRC 1/10 Bycmo - 1/10/2013 6:27 PM
dust75
Score: 100
Status: offline
Hi steve
I'm sure you will be able to sort your car out
If you lay out your new items and replace the old ones one at a time
remove the msc and replace with the esc then plug it into the reciever then do the motors
Hope that helps
Did you manage to sort out your diff ?
Hide Signatures
(in reply to Daviejones)
       Post #: 1559
RE: Subaru Impreza WRC 1/10 Bycmo - 1/10/2013 6:56 PM
Daviejones
Score: 100
Status: offline
Hi Dus
Ive had a look at the diffs but that's it at the mo , will wait till I've got all the new bits and do it all at once ,  think I'm gonna go for the permanent fix with the epoxy resin .
Hide Signatures
       Post #: 1560
RE: Subaru Impreza WRC 1/10 Bycmo - 1/10/2013 6:58 PM
dust75
Score: 100
Status: offline
Hi steve
Cool hope to see some photos soon
cough hint cough cough
Hide Signatures
       Post #: 1561
RE: Subaru Impreza WRC 1/10 Bycmo - 1/12/2013 10:07 AM
Daviejones
Score: 100
Status: offline
Hi Dus
Will post photos when it's finished :-) , have come across a small teething problem with the front wheels Im changing to 12mm hexs but the old 10mm front wheel hex has an added piece on it Bit like a spacer .
What did you use to get around this
Thanks Steve
Hide Signatures
       Post #: 1562
RE: Subaru Impreza WRC 1/10 Bycmo - 1/12/2013 11:36 AM
Ian78
Score: 100
Status: offline
 Sounds good.
You can lock gears with chemical metal too.
Look forward to pics.
Not sure what you mean about the spacer, will have a look later
Hide Signatures
       Post #: 1563
RE: Subaru Impreza WRC 1/10 Bycmo - 1/12/2013 12:31 PM
dust75
Score: 100
Status: offline
Hi Steve
If i remember right I just used the standard silver axle shafts
But I also used plastic hexes off an old nikko car I had in the junk box
I think Ian used the upgraded black axle shafts as the hexes he used were adjustable
You could always upload photos of your problem so we can see
Hope that helps
< Message edited by dust75 -- 1/12/2013 1:40 PM >
Hide Signatures
(in reply to Ian78)
       Post #: 1564
RE: Subaru Impreza WRC 1/10 Bycmo - 1/12/2013 1:57 PM
dust75
Score: 100
Status: offline
hi ian
have a look at page 54
if you need a kick start in rc again
i think it might help lol
Hide Signatures
(in reply to madmunky)
       Post #: 1565
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 11:54 AM
Daviejones
Score: 100
Status: offline
Hi Dus / Ian ,
Will try and add a photo today (not sure how to lol) , I'm using the standard silver axles wasn't aware there was an upgraded axle for it is there much difference between them ? , Ill be using the chemical metal for the diffs .
Hide Signatures
       Post #: 1566
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 9:01 PM
dust75
Score: 100
Status: offline
hi steve
i think the main difference is the black ones are lighter
if your using the standard silver shafts measure width of the shaft to see what size it is
(you also may need to use the old pins as the holes in the silver shafts will be smaller if remember)
you may need these to convert the hexes
http://www.ebay.co.uk/itm/RC-EP-Nitro-1-10-12mm-hex-6mm-Alloy-Locking-Lock-Wheel-Rims-Adapter-Nut-hub-BLUE-/200820021296?pt=UK_ToysGames_RadioControlled_JN&hash=item2ec1ce5830
they do 5, 6, and 7mm thickness
hope that helps
Hide Signatures
       Post #: 1567
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 10:27 PM
Daviejones
Score: 100
Status: offline
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1568
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 10:40 PM
dust75
Score: 100
Status: offline
hi steve
can you take a photo of the silver shaft please
Hide Signatures
       Post #: 1569
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 10:52 PM
Daviejones
Score: 100
Status: offline
Hi dus ,
The 12mm hexs are on order , I'm hoping you don't spot a problem with the axle .
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1570
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 11:28 PM
dust75
Score: 100
Status: offline
hi steve
can i ask which hexes did you order the ones in ian's link or the ones in mine
as the only problem you might have is the size of the shaft and the size of the center
of the hexes
also do you have any wheels for the 12mm hexes yet
Hide Signatures
       Post #: 1571
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 11:33 PM
dust75
Score: 100
Status: offline
hi steve
if i remember rightly the hex goes on the center of the shaft between the thread and the step on the shaft
this is the part you need the measurement for
also the you will need the pins from the rear axles
as the holes it the rear axles are thinner than the standard pins that are used by most rc cars
hope that helps
Hide Signatures
       Post #: 1572
RE: Subaru Impreza WRC 1/10 Bycmo - 1/13/2013 11:55 PM
Daviejones
Score: 100
Status: offline
 Hi Dus
i think I ordered the ones from Ian's link which don't lock , if need be ill order the lockable ones to if you think they will work better ,   12mm hex wheels with foam inserts and tires are in the post :-)
Hide Signatures
       Post #: 1573
RE: Subaru Impreza WRC 1/10 Bycmo - 1/14/2013 1:38 AM
dust75
Score: 100
Status: offline
Hi steve
Wait until the ones in Ian's link turn up
That way you can see if they fit then if they don't order the lockable ones
You may end up using both as the shafts might be different sizes I can't remember
With out getting mine out the loft
Hide Signatures
       Post #: 1574
RE: Subaru Impreza WRC 1/10 Bycmo - 1/14/2013 12:40 PM
Ian78
Score: 100
Status: offline
 Sorry, been busy and not been on.
Will look at mine later, you shouldn't need to lock them on, they run from the pins.
Hide Signatures
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.063RCU1
