Matt Kirsch
Joined: 7/5/2002 From: Rochester, NY, USA Status: offline
quote:
ORIGINAL: LDM Ok my first Lipo with a Trition charger ??? I just attempted to charge my 3 cell 2100mh lipo on the trition . Ok the instructions say to set the charger at 2am 11.1 volts . So I do , the chargeing starts and I watch the battery for over 90 miniutes, feeling the batrey for temp, looking at the screen ect but i just cant tell if its fully chagred . The screen reads . Battery type Lipo some number ???? 11.21 2amps Can someone decramble this ? With regular flights how can I prevent flying to long and dropping this battery below nonminal voltage? My speed control dose not have a built in safty device , is there a light weight plug in product that will shut it down ? lastly on the Triton will it shut down , or beep when the lipo is done ? wil the screen tell me ? To "descramble" the screen, you need to post EXACTLY what the screen says, not "something like," or "something about..." The screen is showing you the progress of the charge. It's probably telling you the battery type, how many mAh it's put into the battery, the voltage measured at the battery, and the charge rate. That's pretty standard for a computerized charger with a display. In the absence of a speed control with a programmable cutoff, a little self-discipline is in order. You'll want to time your flights anyway, so you don't run out of juice when the plane is 1000 feet away, 400 feet up, and downwind in 15MPH gusts. For your first few flights, fly a few minutes, land, and measure the battery voltage. Keep track of how long you're flying. When the pack gets down near 3.0 Volts per cell (9.0 Volts on a 3-cell, 11.1V pack), recharge. Add up the time, knock off a couple minutes for landing, and put it in your timer. When the timer goes off, it's time to land. DON'T IGNORE THE TIMER. The Triton, like any responsible design, will stop charging and beep (if you didn't turn the beeper off) when the battery is fully charged. This should be detailed in the instructions.
