Hitec Receiver (J) 8 channel - Battery Charging?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Hitec Receiver (J) 8 channel - Battery Charging?
Page: [1]
Login
Hitec Receiver (J) 8 channel - Battery Charging? - 7/3/2002 7:50:05 PM
bralex
Status: offline
Hi Mike, I just purchased a "Supreme" 7/8 channel receiver for use with a Futaba transmitter. Everything seemed to work OK on the first flight. The problem I had was with charging the 1200 mah battery in the plane. My charger indicated having put more than 1200 mah in. The battery was showing 5.4 V prior to flying and now after the charge. Once reaching 1200 mah, I turned the charger off with some obvious concern. Does the "Y" connector in "B" channel have anything to do with this? Thanks Mike!
_____________________________
bralex
       Post #: 1
Hitec Receiver (J) 8 channel - Battery Charging? - 7/9/2002 2:45:29 AM
MikeMayberry
Status: offline
The Y harness would not affect this one bit. Typically a battery will accept more Mah than it is rated. What is the problem?
Mike.
(in reply to bralex)
       Post #: 2
Hitec Receiver (J) 8 channel - Battery Charging? - 7/9/2002 6:34:41 PM
bralex
Status: offline
Apparently no problem Mike. I've just never seen this battery take that much charge before, especially since the plane was not flown that long. Most have left the switch on. Thanks Mike!
bralex
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
