2 batteries better then 1 ?????
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-REX 450SA ARF
Seller:  Erick Royer
Details:   $150.00   |  8/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> 2 batteries better then 1 ?????
Page: [1]
Login
2 batteries better then 1 ????? - 5/19/2004 7:38:03 AM
justin_92_92
Status: offline
I was thinking today. My battery pack runs low really fast. I have a 1300mah 7.4v thunder pack lipo.
I got thinking. would it work out ok if I was to put another pack mabey even bigger on my bird with this pack? I could hook them up in a "Y" conection or I could hook the smaller pack to the tail esc and the larger pack to the main esc?
Will this work? will this help? will I blow myself up?
_____________________________
-LHS Owner
-Greatplanes dealer
       Post #: 1
RE: 2 batteries better then 1 ????? - 5/19/2004 8:02:06 AM
RickyT63
Status: offline
Justin,
You dont want to
unless you want to spend $$$ for new ecs boards.
A while back, there was a post about using 1 bat for main & 1 bat for tail sucsessfully. Please keep in mind that by adding battey, you put more weight to your heli and result may not as expected.
Also, after ~15 minutes of flying you need to glt J250 motor cooling down to prolong its life/performance.
Regards
(in reply to justin_92_92)
       Post #: 2
RE: 2 batteries better then 1 ????? - 5/19/2004 4:09:20 PM
justin_92_92
Status: offline
ouch....Im glad I asked about it first. Hey how long do you get out of your thunder pack? I only get like mabey 5 minutes of hover time and then the tail twitches on me. I can fly longer becouse I still get lift but my tail just starts to go twitchy after about 5 minutes. The motor gets really hot too. Think it could be the motor getting too hot and I should do 2 motors?
Oh yeah,,,, I have been doing some forward flight lately too. I even had JABBA go way out and I turned it around and flew it torwards me. Well I was scared for my life but luckely it crashed at my feet.
I bought a bunch of g-10 to make things out of. I made some head stiffeners out of some thicker g-10 and I am going to make the frame this week. Mabey I can customize it the way I want/need for my other heli. Its alot of fun doing things like that.
-LHS Owner
-Greatplanes dealer
(in reply to RickyT63)
       Post #: 3
RE: 2 batteries better then 1 ????? - 5/19/2004 4:17:00 PM
coltech
Status: offline
Justin I've got the same head holding giro as you, I find it gets real twitchy when the pack gets low. Caused me loads of crashes
If at first you don't succeed, buy more upgrades. They won't help, but you'll end up with the coolest helicopter on the bloc
       Post #: 4
RE: 2 batteries better then 1 ????? - 5/19/2004 4:37:39 PM
justin_92_92
Status: offline
yeah but how long do you get for flight time? I get mabey 5 minutes before I see my first glitch. then the come more frequent. I can still fly but its all twitchy and i tends to want to drop out of the sky. I have had numourios crashes due to this also. I am thinking about a 2100mah lipo next. I will see what happens.
-LHS Owner
-Greatplanes dealer
(in reply to coltech)
       Post #: 5
RE: 2 batteries better then 1 ????? - 5/19/2004 4:47:27 PM
coltech
Status: offline
I'm not using li-pos, just a 800mah pack. I get about 7 to 10 mins out of it. But this giro doesn't always perform first time. When it does work it's brilliant . When it doesn't it sucks . I'm wondering if it's something to do with interference or vibration. If I can't solve it I'll concentrate flying my stock HB. I'll then try turning my Dragonfly into the smallest sub micro possible.
I feel a major modding session coming on!
       Post #: 6
RE: 2 batteries better then 1 ????? - 5/19/2004 4:51:50 PM
justin_92_92
Status: offline
well the gyro we have is sensitive to viberations. It wont perform well under viberation. But I have hooked a aerohawk battery up to mine and it cannot keep the tail held like my lipos do. I think it just doesnt have the power to hold the tail. I used the aerohawk batteries becouse my buddy has 3 of them. I found the gyro just couldnt do what it was supposed to do with out my lipo. But I only get a few minutes till twitchy.
When I use my multi meter I read 8 volts on my 7.4 volt batter after it is charged. I wonder if thats a problem.
-LHS Owner
-Greatplanes dealer
       Post #: 7
RE: 2 batteries better then 1 ????? - 5/19/2004 6:05:20 PM
helisfreak
Status: offline
Justin.... justin... 10-15min and you still not happy??
My ep concept run for 3-4 min.. an Im happy...
       Post #: 8
RE: 2 batteries better then 1 ????? - 5/20/2004 3:59:26 AM
justin_92_92
Status: offline
not when it takes me 45 minutes to charge it up. I need to spend lots of money to get more batteries and a few more helli's I need to hover whenever I am awake and not at work......well sometimes when I am at work too.
-LHS Owner
-Greatplanes dealer
(in reply to helisfreak)
       Post #: 9
RE: 2 batteries better then 1 ????? - 5/20/2004 6:09:11 AM
RickyT63
Status: offline
Justin,
With current set-up & TB 1300mah lipo, I get ~ 12-13 minutes before tail starting wagging. About your 5 minutes flight time may cause by the following:
- Your heli is beefy (g10 frame, DD tail, fuses, etc, ...) ---> more weight = less flight time.
- Main motor pinion & main gear mesh are tight.
- I've heard Hobbico charger doesnt fully charge lipo battery.
Regards
       Post #: 10
RE: 2 batteries better then 1 ????? - 5/20/2004 11:24:27 AM
swanne
Status: offline
I don't think that thats quite right. When my Etec 1200 finishes its charge, my trition reads 8.4 volts when its finished charging. I think that your chargers stuffed. You might want to consider getting a swallow digital charger. It's got good value for $$$. I think about $85 US.
Swanne
       Post #: 11
RE: 2 batteries better then 1 ????? - 5/20/2004 1:02:55 PM
justin_92_92
Status: offline
lol I guess I will throw in some more bucks.lol a few more hundred and Ill be happy for another week.
-LHS Owner
-Greatplanes dealer
(in reply to swanne)
       Post #: 12
RE: 2 batteries better then 1 ????? - 5/20/2004 2:17:33 PM
justin_92_92
Status: offline
I have been narrowing this down so far. AS I see it now my heli is ok. I dont have dd tail anymore. I have stock will soon have duel tail. But my heli only weighs in at 274grams....a stock aerohawk(only thing I have rite now to compare with) weighs in at 285grams. And I checked my gear mesh on the bottom and all looks good. couldnt get anymore loos or wopuld strip. Spins nice and freely. So I get the imprestion it is the charger or the battery.
On a totally different note: I have a perfectly good battery and charger for sale lol
-LHS Owner
-Greatplanes dealer
       Post #: 13
Page:   [1]
Page: [1]
