Shock Flyers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> TEAM RCU - Josh Glavin >> Shock Flyers
Page: [1]
Login
Shock Flyers - 5/23/2004 1:54:45 AM
canadianice
Status: offline
Just bought one of these little dinamos need a little input as to were to balance for best prop hanging What a blast for such a LITTLE plane. I'm using an AXI 2208\34 with a 10X4.5 APC and 1375 mill 2 cell lipo pack. Good run times 15\ 20 min depends on how much full throtle I use. Thanks Iceman
_____________________________
Green side is definitely not up!!!
       Post #: 1
RE: Shock Flyers - 5/23/2004 4:30:16 AM
JoshFlies3D
Status: offline
I feel kind of ashamed to say it but, on my last say, 3 shockflyers. I havent measured the balance. Kind of a " That looks about right" and with a Typhoon 6 3D, Apogee 830mAh 2 cell Lipoly batteries and Hitec HS-55 servos in the standard locations ( 1 on elevator, 1 on aileron, one on rudder) theyve balanced nearly perfectly. When I finish building my new Superstar shockflyer I will make sure to measure the balance
(in reply to canadianice)
       Post #: 2
RE: Shock Flyers - 5/29/2004 4:50:30 PM
JohnVH
Status: offline
I believe the manual says 40-60mm back, anywhere in that range is fine.. Love my shockies!
---AIR VH---*FURY FLYER* www.3DFoamy.com
(in reply to JoshFlies3D)
       Post #: 3
RE: Shock Flyers - 6/15/2004 10:13:48 PM
lazylazerflyer
Status: offline
hey guys im thinking about buying one of these things, i plan to buy the 199 package but im worried that the brushed engine won't have enough for good vertical or t rolling i would aprecate your help, thanks
(in reply to JohnVH)
       Post #: 4
RE: Shock Flyers - 6/15/2004 10:17:06 PM
lazylazerflyer
Status: offline
oh yea im also at a 5000 foot altitude
(in reply to lazylazerflyer)
       Post #: 5
RE: Shock Flyers - 12/19/2004 4:16:13 PM
pfact
Status: offline
I have a shockflyer but i'm a little worried because in the past i have flown a hobbylobby biplane and it had so much throw that it went up then strait down. If anyone has any suggestions for throws for high rate and low rate could you pleace respond.
       Post #: 6
RE: Shock Flyers - 12/20/2004 6:15:29 AM
JoshFlies3D
Status: offline
Hey,
Well, for a shocky to be really stable. I would suggest maybe 15 degrees of elevator travel, up and down, 20 degrees of aileron travel, and about 25-30 degrees of rudder travel. This way, it will be easier to fly, but still do mild aerobatics.
Josh
" What are low rates?"
www.Cafreestyle.com
(in reply to pfact)
       Post #: 7
RE: Shock Flyers - 12/20/2004 5:26:51 PM
Devin McGrath
Status: offline
how about all you can get and some expo
Devin McGrath
www.devinrocks.com
       Post #: 8
RE: Shock Flyers - 1/1/2005 4:51:10 PM
firegod2k
Status: offline
got a ikarus extra 330 shock flyer with, PJS 330 SFR motor and thunder power li-poly cells, 730 mah 3 cells (up to 15 A discharge, best li-polys around), and JP ball raced servos, only weights 225 grams, ultra lightweight and with a power to weight ratio of 3 to 1 teh power is amazing about 15 mins before it starts to go flat.
Amazing
(in reply to Devin McGrath)
       Post #: 9
RE: Shock Flyers - 3/15/2005 12:43:30 PM
latif
Status: offline
i am going to buy a shock flyer ( extra ) and i want to install 2208/32 brushless motor is it enough ?
(in reply to firegod2k)
       Post #: 10
RE: Shock Flyers - 3/16/2005 1:27:42 AM
JoshFlies3D
Status: offline
That would be more than enough power. I would suggest a Axi 2204-54 on 3s or a Little Screamers motor, over that. www.littlescreamers.com, or Hobby Lobby- www.Hobby-lobby.com has the Axi motors.
Josh
www.Cafreestyle.com
(in reply to latif)
       Post #: 11
RE: Shock Flyers - 12/9/2005 10:59:04 PM
shakeelsid
Status: offline
Hi guys, has anyone tried a 180 size geared motor with Ikarus 10-5.5 prop, drawing around 5 amps - what weight model could it prop hang.
Prop calc says 160 gram thrust, my fish and kitchen scales say 180 gram - what is the real world figure.
May the sky be always blue as you fly across it, and may the earth rise softly to meet you at your destination
       Post #: 12
RE: Shock Flyers - 12/10/2005 10:09:41 PM
kidpilot
Status: offline
The Calc Is Usually Pretty Close!!!
(in reply to shakeelsid)
       Post #: 13
RE: Shock Flyers - 7/14/2008 6:57:48 PM
SigMan
Status: offline
anyone still flying the SuperStar? i see the last post was in 12/10/2005 ...just curious.
Club Saito Member #1
AMA# 542304
(in reply to kidpilot)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
