dennis
PA, USA Status: offline
First of all the Tartan twin is probably the lightest twin of 2.7 C.I that you will ever buy or fly. It has one of the highest power to weight ratios of any motor in it's displacement. It does start backwards but only of you dont put some heft into your flip of the prop, it's easier at times to bump it off compression and let it kick to life. To reverse it just close the throttle to where it's about ready to quit and drag the spinner. It will bump and go the right direction. Usually we never have to touch the spinner the motor will do it it'self. Really better to use a 20 inch prop or better, an 18/8 will tend to run it close to the bloodline of 11K and you can really ruin your day when the shafl lets go. Never use nitro in the motor. It has an 11.1 compression ratio and will seriously overheat and fry the right cylinder if you do insist on doing it. Motor comes in two states of tune. The standard Tartan and the Super tartan which has a true Schnurle port and a slightly better carb arrangement and higher finned heads. There are some nice after market items available for the motor and decent mufflers from Bisson. The stock are for looks and to say that there are mufflers with the motor. Don't use them if you want to keep your field. If that doesn't matter then ler her rip and enjoy the wail of a twin at full song. Cline regulators are the sole importers of the motor and they don't list prices but ask you to call, reason, they are pricey at $750.00 plus. Motors show up somewhat often on the bay and here in the classified section with prices usually at $300.00 to $550.00. Oh and one more thing, a 2.7 C.i glow motor is not known for it's fuel efficiency. We used 32 to 50 of of fuel for our planes and it was cheaper to buy a 55 gallon drum of menthanol and a case of Klotz KL100 and mix our own fuel. You need less then 10% oil in a properly broken in motor and I usually used 7%,'I have about 5/6 of the twins in both varients and about the same on singles.Also a diesel twin and single, however your not ready for that, are you? Dennis
