fcawth
Joined: 5/4/2003 From: Beltsville, MD, USA Status: offline
I am fairly certain that the cause is a tighter than normal motor. This makes the output of the servo seem quite a bit tighter, since the "tightness" is amplified by all of the gears. I took my tight one apart and everything seemed fine up to the motor. I have one tight and one loose on my elevator halves, and flight performance seems OK up to this point. I have about 15-20 flights on the plane now. One thing that I might do sometime is measure the current going through each servo when they are cycling with the control surface disconnected. If the tight one is drawing significantly more current, then I might be concerned. On mine, it seems like there is more "slop" in the tight ones, but I think this is because it takes more force to turn the motor. I don't think that there really is more slop, just that the looser ones can more easily spin the motor when being driven in "reverse" from the output shaft. Are these servos "tuned" at the factory (i.e deadband, control loop gains, etc..) or does each one get programmed with the same default values??? Hope this makes some sense, FC
