fcawth
Joined: 5/4/2003 From: Beltsville, MD, USA Status: offline
Thanks for the reply. It seems like something down the line in the gear train is tighter, because there is more noticable "slop", but the motion is tighter once it gets moving. On the smoother ones, when I move the arm with the servo off, it seems like there is very little slop because the motor seems to move whenever I move the arm. On the "tighter" ones, you can click it back and forth a bit with little resistance even with the motor off, then you get more resistance than normal once the motor (or whatever is tight) does move.. When I power it up and move it slow (i.e. cycle function on 9C radio), it seems to oscillate a bit more than I would like, and it really seems like this is caused by the tightness issue coupled with the servo loop controlling the motor oscillating slightly. (You see this kind of thing alot when tuning industrial servo loop PID parameters when there is friction somewhere) I thought about opening up the case and having a look. Does this void the warranty?? I am thinking about picking up another servo so I can send one of the tighter ones in. I put in a couple of flights without an incident, but it still makes me nervous since the plane that I am using the servo on is by far my biggest money pit yet!! I just have to get that SWB arm off !!! Thanks again, FC
