digi16v
NJ, USA Status: offline
MIL, i can help you with the throttle problem, cause i had the same problem with mine. its got to do with your throttle servo. the L shape servo horn needs to be readjusted. unloosen the screw, pull it up and move the L shape a few notches counter clockwise. this shoudl help you out in that problem. about the steering i am not sure, i bought my car used and one of the first things thati changed was the steering bellcrank. get the one for the rs4 not 3rd edition- if you buy anything make sure it is from the nitro rs4 or rs42 rtr or kit. not 3rd edition. i am not sure if the pro stuff fits, thats electric. TAM. glad to see you get some parts for the car, what did you pick up? you can get my email address from here. i will return with old pics of mine. (there really bad). FYI: should be gettin in the servo- hope to be running FM in a few days, will let you know if the steering is alot better with a better servo.(MIL)
