P80 temp going nuts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> P80 temp going nuts
Page: [1]
Login
P80 temp going nuts - 5/26/2004 2:46:14 AM
JohnVH
Status: offline
Hey, first run of the day, P80 v4 ecu ran great, started fine, was fine. Then later, went and turned on the power, and it kept spooling up the starter as it thought it was hot, screen showed 450*c+ and it was so cool you could hold onto it. Reading were erratic, jumping around.. Any thoughts? Later on after shutting it off for a while, it was fine again, and started and ran good again...
Any thoughts?
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 1
RE: P80 temp going nuts - 5/26/2004 2:54:30 AM
mr_matt
Status: offline
I would say bad EGT probe. K type thermocouple show very high temps on most failures.
Check with the shop to make sure, they sell the probes as spares, good to have one in any case
Matt
JetCat rep
(in reply to JohnVH)
       Post #: 2
RE: P80 temp going nuts - 5/26/2004 4:04:06 AM
JohnVH
Status: offline
Ah, OK. Thanks Matt.
Ill give them a call tomorrow.
(in reply to mr_matt)
       Post #: 3
RE: P80 temp going nuts - 5/26/2004 6:39:07 AM
mr_matt
Status: offline
You going to have the same problem, they are incommunicado until 1 june.
Matt
JetCat rep
       Post #: 4
RE: P80 temp going nuts - 5/26/2004 6:45:37 AM
JohnVH
Status: offline
Dang, thats right, Bob told me that already.....
PS. you got one laying around?
       Post #: 5
RE: P80 temp going nuts - 5/26/2004 7:00:48 AM
KFalcon
Status: offline
Thats to bad, my P-120 is doing the same thing. I do get an error of "failed temp sensor" though, is that the same problem?
< Message edited by KFalcon -- 5/25/2004 11:01:01 PM >
Kenny Falconer - California Jets - April 2-5, 2009
www.ca-jets.com
       Post #: 6
RE: P80 temp going nuts - 5/26/2004 7:01:38 AM
JohnVH
Status: offline
Hmm, mine never said that.. On min the temp reading was everywhere..
(in reply to KFalcon)
       Post #: 7
RE: P80 temp going nuts - 5/26/2004 2:10:25 PM
mr_matt
Status: offline
Could be. I will tell Bob you guys need help today, unfortunately I cannot help, got real job stuff to do the rest of the week out of town.
He usually has plenty of those probes
Matt
JetCat rep
       Post #: 8
RE: P80 temp going nuts - 5/26/2004 4:29:31 PM
JohnVH
Status: offline
Sweet, Id appreciate it Matt!
       Post #: 9
RE: P80 temp going nuts - 5/26/2004 8:10:07 PM
KFalcon
Status: offline
Thanks Matt!
www.ca-jets.com
       Post #: 10
RE: P80 temp going nuts - 5/27/2004 2:42:08 PM
Bob_Wilcox
Status: offline
On June 1st we will be up and running. The new phone number and address will be listed then. (The phone company still doesn't have our phones working right yet!!!!) Right now, it is just me and a couple contractors finishing the inside of the building. I only have time to answer a couple of emails at 6:00AM.
I am sure you just need sensors and we have them in stock but I can't do anything about it until Tuesday.
Bob Wilcox
JetCat USA, LLC
       Post #: 11
RE: P80 temp going nuts - 5/31/2004 7:35:43 AM
KFalcon
Status: offline
Thanks Bob, I will call on Tuesday to order one.
www.ca-jets.com
(in reply to Bob_Wilcox)
       Post #: 12
RE: P80 temp going nuts - 5/31/2004 3:27:22 PM
JohnVH
Status: offline
I have a feeling that there will be alot of calling on tues! Hope I can get through.
       Post #: 13
RE: P80 temp going nuts - 5/31/2004 5:51:43 PM
KFalcon
Status: offline
I know what you mean. I will be on the horn dialing 5 minutes before they open.
www.ca-jets.com
       Post #: 14
RE: P80 temp going nuts - 5/31/2004 8:03:05 PM
JohnVH
Status: offline
quote:
ORIGINAL: KFalcon
yep, now that I know that, Ill call 6min before.
       Post #: 15
RE: P80 temp going nuts - 6/1/2004 6:11:35 PM
KFalcon
Status: offline
www.ca-jets.com
       Post #: 16
RE: P80 temp going nuts - 6/1/2004 6:48:29 PM
JohnVH
Status: offline
Ive called a few times today, no answer, got the machine, left a message..
You get through or a call back?
       Post #: 17
RE: P80 temp going nuts - 6/1/2004 7:20:52 PM
KFalcon
Status: offline
No luck here either. I called and got the new number, but when I called it a guy answered and said BGW. There not changing their name also right?
What number are you dialing?
www.ca-jets.com
       Post #: 18
RE: P80 temp going nuts - 6/1/2004 7:22:24 PM
