iacolb12
TX, USA Status: offline
I assume you have the Plus so that means you have the AM radio. There, most likely, is your problem. If you run in a urban enviro or at a large event with a lot of interference you'll get that with an AM. If it's an FM, check your crystals, make sure your antenna is screwed in tight and check all your wires as well. A good way to test your crystal without trying a different one, move your TX all around and if the servos jerk in response then it's probably your crystal. (or worse a loose wire/solder in the TX eeek! ) quote:
ORIGINAL: sgfdotcom ...put the tc3 on the track and for the lineup and all of a sudden, the throttle and steering started twitching, tx batteris ok rec batteries...any ideas?
