RE: Lets see your WW1 Fokker's
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Lets see your WW1 Fokker's
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Lets see your WW1 Fokker's - 12/26/2004 3:04:35 AM
mrbigg
Status: offline
here is one more. by the way, the covering is 21st century fabric. first covered in black, the trimed in yellow and white.
Click to see fullsize image.
Click for fullsize
_____________________________
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to mrbigg)
       Post #: 126
RE: Lets see your WW1 Fokker's - 12/26/2004 4:43:06 AM
Tmoth4
Status: offline
mrbigg,
Nice job on the DR1! I found the best way to land mine is with a slight amount of power on, and delicately touch down and let it roll on the mains. If I try to 3-point it I get all messed up. Once the tail settles down on that plane it loses directional control.
Jim
"I'm TRYIN' to think...but nothin' happens!!"
       Post #: 127
RE: Lets see your WW1 Fokker's - 12/29/2004 11:13:02 PM
pkf3
Status: offline
Hello all..my first time posting here...I am thinking of building the Balsa USA Fokker D.VIII. My question is...as I am living on a military paycheck...what engine would be recommended for this plane that would not require selling the wife and kids to finance?
(in reply to Tmoth4)
       Post #: 128
RE: Lets see your WW1 Fokker's - 12/29/2004 11:24:56 PM
pkf3
Status: offline
A few pics of my Global Fokker D.VII...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to pkf3)
       Post #: 129
RE: Lets see your WW1 Fokker's - 12/29/2004 11:25:42 PM
p51f4f
Status: offline
I have 4 of the Balsa USA kits. And I fly at an altitude of 5500 ft. I have installed a G-26 in my Dr-1, a Ryobi 31 in my D-VIII, a G-38 in D-VII and, a YS 120 in my sopwith pup. Any of these engines should do the trick. The ryobi are the cheapest and run good enough for the planes. but the torque is more with the gas engines than the 4 stokes, at least up here.
< Message edited by p51f4f -- 12/29/2004 11:27:52 PM >
(in reply to pkf3)
       Post #: 130
RE: Lets see your WW1 Fokker's - 12/29/2004 11:27:32 PM
p51f4f
Status: offline
(in reply to pkf3)
       Post #: 131
RE: Lets see your WW1 Fokker's - 12/29/2004 11:28:11 PM
pkf3
Status: offline
Three more...flies great...lands on a gnat when throttled back in the wind.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to pkf3)
       Post #: 132
RE: Lets see your WW1 Fokker's - 12/30/2004 12:22:06 AM
deljon
Status: offline
Nice looking DVII
Keep us posted on the progress of your DVIII. Thats why I started this thread, so that Fokker lovers could keep in touch and show off their prized birds.
I'm building the GTM low cost DVIII, with some extries like the cockpit kit, ammo box and a few other goodies.
Have fun.
Del
Click for fullsize
Click for fullsize
(in reply to pkf3)
       Post #: 133
RE: Lets see your WW1 Fokker's - 12/31/2004 3:26:06 AM
pkf3
Status: offline
Anyone built the Ben Buckle Fokker D.VIII? If you have, would like to hear your thoughts about the kit and performance.
(in reply to deljon)
       Post #: 134
RE: Lets see your WW1 Fokker's - 1/2/2005 2:53:27 AM
pkf3
Status: offline
Would a 91 Four Stroke be sufficient to power the BUSA Fokker D-VIII? Also, does this plane use standard servos? Keep the pictures and ideas coming..........................
(in reply to pkf3)
       Post #: 135
RE: Lets see your WW1 Fokker's - 1/2/2005 4:32:22 PM
RCJake-rcu
Status: offline
Here is a photo of my latest DR-I. It is an arf from Polk's Hobbies that came red, but was stripped & recovered with white Econokote and used Monokote trim sheets for the markings and stripes. My white tripe is modeled after the one on display at the EAA museum located in Osh Gosh, WI.
It is powered with an AXI 2212/20 brushless outrunner motor and uses a Jeti speed controller, Polk's Hobbies servos (4) and a Thunder Poers 11.1v 2100ma Li-Poly battery pack. Flights of 25 minutes on one charge and it flies great. I fly from a blacktop runway and the take-offs are a breeze and the landings are not difficult. Just make wheel landings (not three point) and be on the rudder when it slows down.
BTW, I assembled another of these tripes for a very good friend that is equipped the same as mine, only it was left red and used a Hacker speed controller.
Click for fullsize
(in reply to pkf3)
       Post #: 136
RE: Lets see your WW1 Fokker's - 1/3/2005 1:38:23 AM
deljon
Status: offline
pkf3....I think a 91 four stroke would be a bit light on power for that plane. I think they're supposed to come in around 14-15 lbs., it would probably be marginal at best. I would go at least a 150.
rcjake.....Great look'n tripe.
Del
(in reply to pkf3)
       Post #: 137
RE: Lets see your WW1 Fokker's - 1/3/2005 2:25:22 AM
RCJake-rcu
Status: offline
mrbigg,
What is the white stuff all over the ground and on your roof. Did some white sand blow through?
       Post #: 138
RE: Lets see your WW1 Fokker's - 1/3/2005 4:37:19 AM
pkf3
Status: offline
deljon..thanks. I'll keep that in mind
       Post #: 139
RE: Lets see your WW1 Fokker's - 1/4/2005 3:24:35 PM
mrbigg
Status: offline
ha ha, very funny. i see how you are! if i had any sense i'd move where you are to fly year round!
(in reply to pkf3)
       Post #: 140
RE: Lets see your WW1 Fokker's - 1/4/2005 10:43:28 PM
pkf3
Status: offline
Does anyone know of a decent set of plans for a Siemens-Schuckert D.IV / V? I know there was a construction artilce in M.A.N., but that one is a little too big (80 inch) for my liking.
