Blackie
Joined: 2/10/2002 From: Austin, TX, USA Status: offline
I just so happen to be working on replicating a Fokker Eindecker III, only thing is, I will be using an already made ARF to do it with. The World Model SS60 will be stripped down then recovered with the cream white and silver coloring in areas to match the scale version, The Maltese cross will be added at all points to scale. The tail will be removed and altered to fit a split-level elevator I will re-manufacture a rounded vertical stab and rudder to match the scale version. The wing, using a large block of balsa I plan on carving out a cock pit and gluing it to the top of the wing in hopes it will look authentic, As far as the landing gear, it will be changed to a tail dragger but being its an 80" wing I don't think it will support that narrow main landing gear that comes with the scale, so I might have to use standard. I believe World Models were trying to replicate the E III anyway so I figured I would take it even further. The reason I am using an Arf was because I already had this plane but met its demise, the wing came out with no damage only purchased another fuse. Once its under way I'll be taking pics. Blackie
_____________________________
Please visit my web site below.
