Charging Error, mental type    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> Charging Error, mental type
Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
Charging Error, mental type - 7/6/2002 12:43 AM
bob_nj
Score: 105
Last Login: 5/1/2012
Status: offline
I thought I might make this seperate instead of mixing it in with the flight modes post. Anyway, my question to Danny was;
Why didn't my 10X blow up when I accidentally plugged my Futaba C/10 charger into it, twice! From what I gather, the battery in the 10X houses the charging circuit with a fuse. Evidently my 50mah charger didn't have enough current to blow the fuse (whew). When I made this same mistake with my SX, it was lights out! So to summarize, since the fuse didn't blow everything is fine and the system functions and operates normally at home and at the field. {yes}
If this fuse would have blown though, (1) Is it user serviceable and (2) Is is logical to assume that the current never gets to the motherboard like it can with the SX. (3)If I had an additional battery pack laying around, I could just pop it in and fly? If this is the case, it is a much better idea and system than having to send it in for service for a blown fuse. Below is Dannys' resonse to my original question;
"The reverse current must not have been high enough to blow the fuse if it is still taking a charge. If the battery will not take a charge, the fuse in the battery charging circuit is blown. Otherwise, it sounds like you got lucky and didn't damage anything. "
Thanks_bob
Hide Signatures
       Post #: 1
Charging Error, mental type - 7/6/2002 12:52 AM
dsnyder
Score: 100
Last Login: 4/18/2012
Status: offline
Bob,
It is user servicable provided you are comfortable with working with soldering etc. It is a soldered in fuse. If there is warranty left on the system, I assume there is, there is less risk just sending it in. If you do something that causes any other problems down the road, we may not cover it. The current should never get to the motherbord in a 10X. Yes, you certainly could do that. I hope this helps!
_____________________________
Danny Snyder
Horizon Hobby / Team JR
Hide Signatures
(in reply to bob_nj)
       Post #: 2
So COOL... - 7/6/2002 1:02 AM
bob_nj
Score: 105
Status: offline
I could just send the battery pack in right?
To clarify, Are blown fuses a non-warranty issue?
Hide Signatures
       Post #: 3
Charging Error, mental type - 7/6/2002 2:13 AM
dsnyder
Score: 100
Status: offline
Bob,
On a reverse polarity it is. It just depends on the circumstance behind the reason the fuse blew. Sometimes they are covered, others they are not. Yes, you could just send the battery in. It is a quick repair provided the fuses are in stock.
Danny Snyder
Hide Signatures
       Post #: 4
Charging Error, mental type - 7/6/2002 2:14 AM
dsnyder
Score: 100
Status: offline
That should have said, is not for the reverse polarity. Sorry
Danny Snyder
Hide Signatures
       Post #: 5
Got it - 7/6/2002 3:42 AM
bob_nj
Score: 105
Status: offline
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.188RCU1
