3 cell 1200 mah lipo    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> 3 cell 1200 mah lipo Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
3 cell 1200 mah lipo - 5/29/2004 6:28 AM
ifly04
Score: 100
Last Login: 6/28/2004
Status: offline
I just got this 3 cell pack after deciding the 2 cell just wasn't enough. My question is I leave it on the charger for two or three hours and the battery never charges fully it flies for about ten minuets and dies. Someone mentioned that they thought I had to have something that put out more voltage than using a 12volt battery would allow to peak it. Is this true or is there something wrong with the pack.
I hope this makes since
thanks for any help
Hide Signatures
       Post #: 1
RE: 3 cell 1200 mah lipo - 5/29/2004 6:46 AM
beldraak
Score: 100
Last Login: 12/26/2006
Status: offline
what kind of charger are you using?
Hide Signatures
(in reply to ifly04)
       Post #: 2
RE: 3 cell 1200 mah lipo - 5/29/2004 7:42 AM
ifly04
Score: 100
Status: offline
it is a bel charger
Hide Signatures
(in reply to beldraak)
       Post #: 3
RE: 3 cell 1200 mah lipo - 5/29/2004 8:02 AM
Chris-B-chips
Score: 100
Last Login: 12/31/2007
Status: offline
do you have it on a 3 cell setting. and if you are running them to flat then have you got the BEC on your speed controler on the 3 cell setting. if not it would discharge to below 3v per cell causing permenant damage.
Hide Signatures
       Post #: 4
RE: 3 cell 1200 mah lipo - 5/31/2004 5:42 AM
Mrbmp
Score: 100
Last Login: 6/6/2004
Status: offline
A 3 cell lipo should peak at 12.75 v
Hide Signatures
(in reply to Chris-B-chips)
       Post #: 5
RE: 3 cell 1200 mah lipo - 6/9/2004 7:03 PM
mumblety-peg
Score: 100
Last Login: 5/14/2012
Status: offline
I have the same problem and the same charger. This charger needs more voltage to charge a 3 cell pack. I was a bit ticked off when I found this out. The ad for the charger warned of "reduced charge current" when charging 3 cells. I'd say a charge current of ZERO is a not exactly reduced.
Anyway, I have an Astro pwr supply. So it's ez to increase the voltage. I wish I'd sent it back though. A few more dollars would have gotten me a charger without the "reduced current" on 3 cells.
Hide Signatures
(in reply to Mrbmp)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.535RCU1
