Counter-rotating props on a single engine?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Counter-rotating props on a single engine?
Page: [1] 2   next >   >>
Login
Counter-rotating props on a single engine? - 5/29/2004 10:00 AM
scubyfan
Score: 100
Last Login: 11/15/2005
Status: offline
Hey guys,
I'm thinking about doing a scale model of a certain plane, and it is set up like this: http://www.scaleworkshop.com/gallery/images/xp56ms_4.jpg
Is there a way to get one engine to rotate two propellors in opposite directions? Has anyone done this on a model, and if so, how?
Thanks in advance!
Hide Signatures
       Post #: 1
RE: Counter-rotating props on a single engine? - 5/29/2004 12:24 PM
bigchap
Score: 100
Last Login: 11/16/2008
Status: offline
i have seen an article in a magazine here in the u.k.,it was about 2 years ago but i can't remember what magazine it was,they were using a gearbox which was commercially available,i know o.s. made gearboxes for i.c. motors so perhaps it was one of theirs,sorry i can't tell you more but i'll try and find out.
Hide Signatures
(in reply to scubyfan)
       Post #: 2
RE: Counter-rotating props on a single engine? - 5/30/2004 1:18 AM
scubyfan
Score: 100
Status: offline
That seems to be the ticket. Please let me know if you find out.
Can anyone else comment?
Hide Signatures
(in reply to bigchap)
       Post #: 3
RE: Counter-rotating props on a single engine? - 5/30/2004 4:29 AM
CP140
Score: 100
Last Login: 1/8/2009
Status: offline
You would need to end up with a hollow drive shaft with an internal shaft turning the opposite direction to get contra rotating props. You're going to need gears etc capable of running at the max rpm you expect your engine to develop and you would need to keep it fairly light. Sounds like you've got your work cut out for you!
The Tupolev TU-20/TU-95 "Bear" uses contra-rotating props... not quite sure how it was set up. Unfortunately none of my books are very specific about the "plumbing".I remember seeing something about a gear box for an OS engine, but I think it was a gear reduction drive... not sure how you would adapt it for use with contra props...
I'd suggest making friends with a really good machinist! Good look with your project!
Hide Signatures
       Post #: 4
RE: Counter-rotating props on a single engine? - 5/30/2004 5:23 AM
scubyfan
Score: 100
Status: offline
Hi,
If there is no one making these, I will be forced to do one from scratch. Obviously it will take experimentation (and some money...), but it is doable. I'm just surprised that such a thing is not available on the market. How difficult would it be do hardened metal gears to reach this end? So many airplanes and craft have used counter-rotating props, and it does have advantages, other than the scale appearance.
Hide Signatures
(in reply to CP140)
       Post #: 5
RE: Counter-rotating props on a single engine? - 5/30/2004 6:00 AM
JohnVH
Score: 160
Last Login: 5/19/2013
Status: offline
heck, if someone can make a working turbofan, sure this can be done too
_____________________________
[quote]ORIGINAL: jefflangton
Time to bend over and let your head pop out!!!![/quote]
Hide Signatures
       Post #: 6
RE: Counter-rotating props on a single engine? - 5/30/2004 6:11 AM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
Wish I still had access to a machine shop. Sounds like a fun project.
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to JohnVH)
       Post #: 7
RE: Counter-rotating props on a single engine? - 5/30/2004 7:11 AM
scubyfan
Score: 100
Status: offline
I found a fellow who can do one for me within the next few months. I will let you guys know how it turns out.
Is $150 for a one-off, fully machined, enclosed, bearing-laden gearbox a good price? I'm not too sure on what the going rates are for such things.
Hide Signatures
(in reply to MinnFlyer)
       Post #: 8
RE: Counter-rotating props on a single engine? - 5/30/2004 7:28 AM
rmh
Score: 252
Status: offline
A Russian modelerdid abeautiful scale model years back and I think, did his own engines and propboxes .
scale buffs probably know who did this -
Libby is still watching you
Hide Signatures
       Post #: 9
RE: Counter-rotating props on a single engine? - 5/30/2004 9:16 AM
JohnVH
Score: 160
Status: offline
I would think $150 would be cheap. Sounds like alot of work, which by the hour gets spendy.
Hide Signatures
(in reply to rmh)
       Post #: 10
RE: Counter-rotating props on a single engine? - 5/30/2004 9:42 AM
CP140
Score: 100
Status: offline
$150! I'd say you got a bargain. Will you be able to post pics/weights etc? It should be quite the showpiece when it's done...
Hide Signatures
       Post #: 11
RE: Counter-rotating props on a single engine? - 5/30/2004 9:53 AM
scubyfan
Score: 100
Status: offline
Hi guys,
I will definitely give you guys all the info once it arrives and is tested. That will be in a few months, though.
Hide Signatures
(in reply to CP140)
       Post #: 12
RE: Counter-rotating props on a single engine? - 5/30/2004 12:01 PM
bigchap
Score: 100
Status: offline
sorry,scuby,i have drawn a blank,but i am going to try a uk forum and see if anyone remembers the article.
Hide Signatures
       Post #: 13
RE: Counter-rotating props on a single engine? - 5/30/2004 2:23 PM
Chevelle
Score: 110
Last Login: 5/5/2013
Status: offline
With all the power available in today's R/C engines, the counter-rotating props aren't needed to fly the plane. It seems to me that it would be easier to extend the prop shaft, put on a dummy prop with a bearing in it that will slip on the shaft and then add the fixed drive prop. The dummy prop would rotate in the first props wash. If would spin in the opposit direction if the pitch was reversed. I've never done it but it does seem easier.
Hide Signatures
       Post #: 14
RE: Counter-rotating props on a single engine? - 5/30/2004 3:04 PM
MinnFlyer
Score: 390
Status: offline
Chevelle's right, but it wouldn't be as Cool.
And 150 bucks is dirt cheap!
Hide Signatures
(in reply to Chevelle)
       Post #: 15
RE: Counter-rotating props on a single engine? - 5/30/2004 3:42 PM
scubyfan
Score: 100
Status: offline
Yes, it does seem easier and a lot of people have done it (like the guy who built that Bear), but being an obsessive ****, it wouldn't feel the same to me, knowing it's a dummy. I'm really not doing it for gain of any kind, perhaps other than personal satisfaction.
quote:
ORIGINAL: Chevelle
Hide Signatures
       Post #: 16
RE: Counter-rotating props on a single engine? - 6/1/2004 11:21 PM
ampbomber
Score: 100
Last Login: 4/30/2013
Status: offline
Here are a couple of articles on contra-rotating prop gear boxes.
R/C Scale Modeler Oct '88 had a gear drive for an IC engine and R/C Scale Modeler April '89 had one for an electric with gear and belt drive.
I'm currently working on an electric Tu-95 (107 inche WS) that will have contra-rotating gear boxes using the miter gear concept. Scale prop size is about 12".
Here is the gear article. I'll post the other in following post.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: Counter-rotating props on a single engine? - 6/1/2004 11:23 PM
ampbomber
Score: 100
Status: offline
Here is the second article
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ampbomber)
       Post #: 18
RE: Counter-rotating props on a single engine? - 6/2/2004 1:32 AM
scubyfan
Score: 100
Status: offline
Wow, thank you so much!
Hide Signatures
       Post #: 19
RE: Counter-rotating props on a single engine? - 6/2/2004 3:26 AM
F1992
Score: 100
Last Login: 5/18/2013
Status: offline
TO: scubyfan
Sir!
I have analogical problems at the same time but only for FP(Fly platform).
Contr-rotation for me - NO PROBLEM, because props ave his shaft.
There is as far i understand more dip ruts...
Therefor i would like to know before how you decided problem w/ prop.?
did you using symmetrical profile prop? What is brand? What is pitch direction?(tractor/pusher)?
please response asap. OK.
Please E-mail me. <fstaras@cs.com>
PS. May be it will be useless but
Two monthes ego i sow or magazine RC or on forume differential-device for contr-rotation (very small for electric models)
Hide Signatures
       Post #: 20
RE: Counter-rotating props on a single engine? - 6/2/2004 3:35 AM
scubyfan
Score: 100
Status: offline
Howdy,
I'm sorry, but I do not understand your question. I will not be making the gearbox, if that's what you're asking, so any technical questions regarding that I will not be able to answer.
What was it that you wanted to know?
Hide Signatures
(in reply to F1992)
       Post #: 21
RE: Counter-rotating props on a single engine? - 6/2/2004 5:02 AM
ampbomber
Score: 100
Status: offline
quote:
ORIGINAL: scubyfan
Howdy,
Scubyfan,
I think what F1992 is asking is, what are you going to use for props after you get the gear box? I have to agree with him, making the gear box is not a problem. Propellers will be your biggest problem especially if you want scale props as shown in your picture. From the beginning you have to pick a scale for your project that you can power efficiently with your gearbox-prop combo.
Hide Signatures
       Post #: 22
RE: Counter-rotating props on a single engine? - 6/2/2004 7:42 AM
scubyfan
Score: 100
Status: offline
I will be getting the propellors custom made, also. Everything has been shrunk down to scale, and so will be the propellors.
Hide Signatures
       Post #: 23
RE: Counter-rotating props... and PROBLEM W/PROP - 6/2/2004 7:42 PM
F1992
Score: 100
Status: offline
Friends!
I have problem almost clouse to scubyfan...(project w/FLY PLATFORM).
I don`t have of experience in field RC Planes, but i have big experience as aviation engineer and inventor...
So, my problems are:
1.The second prop on my FP have to have:
a/ counter-rotation
b/ for 'tractor" prop pitch - conditional coll "negative" (tractor prop pittch -conditional coll 'positive")
c/ "tractor' pitch "negative" as far i know, don`t making.
d/ as rule blades of props making with unsymetrical profile, therefore it isn`t possible to use as pusher prop.
e/prop w/changing pitch, as minimum $105
2. Therefore my project under sword of Damocles....and lost money
3. Who have idea or recommends PLEASE
Hide Signatures
       Post #: 24
RE: Counter-rotating props... and PROBLEM W/PROP - 6/2/2004 8:20 PM
ampbomber
Score: 100
Status: offline
F1992,
Check out this thread. We did a lot of talking about C-R props here. Go to post #24 of this thread for more info on props.
http://www.rcuniverse.com/forum/m_1448339/anchors_1448339/mpage_1/key_contra%252Drotating/anchor/tm.htm#1448339
BTW, what plane are you thinking of modeling?
Hide Signatures
(in reply to F1992)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
