Flyboy Dave
CA, USA Status: offline
I think there is but one grade of medicinal castor from the manufacturer, and three grades of second and later presses of industrial castor. I ran a ringed OS 60 FSR for 15 years until it had no compression what so ever. When I took off the ring, although worn out, was free....not stuck. I removed it with my fingernail from the piston. I figured it was stuck from all that castor, and all that use. I was wrong....it was as free as could be. In all the years I ran straight castor in my racing motorcycle engines I never stuck a ring or had any carbon build up worth mentioning. I think if the engine is run at the proper temperature, even though it is running in extreme, hard use....the carbon residue is minimized. I have often read about the evils of the castor/carbon in the engines, but I have never seen it. I've certainly used my share of castor in my lifetime. FBD.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
