RE: Castor oil - A final word?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Castor oil - A final word?
Page: <<   < prev  17 18 19 20 21 22 23 [24] 25 26   next >   >>
Login
RE: Castor oil - A final word? - 12/25/2007 11:06:57 PM
skiman762
Status: offline
castor is a vegetable oil
http://en.wikipedia.org/wiki/Castor_oil
_____________________________
land of the FREE: you're free to get a JOB not a handout.
home of the BRAVE: they paid for it and you're enjoying it
(in reply to Flyboy Dave)
       Post #: 576
RE: Castor oil - A final word? - 12/25/2007 11:23:58 PM
Flyboy Dave
Status: offline
Yes it is a type of vegetable oil, but not a cooking oil made for human consumption
like most vegetable oils.
That Wikipedia article does not have the word "de-gummed" in it, nor does it say
what the "gum" might be, why or how it is removed....nothing about de-gumming.
I'm starting to wonder since regular vegetable oils (cooking oils) are certainly
de-gummed....folks just assumed that castor is de-gummed as well.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to skiman762)
       Post #: 577
RE: Castor oil - A final word? - 12/25/2007 11:34:21 PM
skiman762
Status: offline
I agree with you I'm sure the fuel makers can't and don't do anything to the castor they use to blend our fuels with
       Post #: 578
RE: Castor oil - A final word? - 12/26/2007 12:00:06 AM
skiman762
Status: offline
Dave
here's a better site that has castor listed then the processing steps
seems the pressing gets the oil from the seed and degumming is one of the refining processes
http://ces.iisc.ernet.in/energy/HC270799/HDL/ENV/enven/vol238.htm
       Post #: 579
RE: Castor oil - A final word? - 12/26/2007 12:15:49 AM
skiman762
Status: offline
Here's another on
http://www.nyscc.org/news/archive/tech0802.htm
       Post #: 580
RE: Castor oil - A final word? - 12/26/2007 12:35:54 AM
blw
Status: offline
I think that degummed is a term used to differentiate between the first pressing and all others. The term is a reversal of the actual process, since the first batch is pure and naturally free of additional substances. The problem comes with subsequent extraction techniques.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 581
RE: Castor oil - A final word? - 12/26/2007 12:40:14 AM
skiman762
Status: offline
It looks like it's a seperate process from the press extration of the crude or virgin oil
Many cosmetics applications require cold-pressed, virgin oil. On the other hand, some seeds are too low in oil to economically remove the oil by pressing. In any case, once you have the crude oil, you can move onto refining. Refining is done by filtering the oil through clay or silica, which can remove color. In an operation called "degumming," alkali in water is added to the oil and some ingredients, especially fatty acids and one called "phospholipids" are solubilized or precipitated or are filtered out. Finally, steam can be passed through the oil to remove odor in an operation called deodorization. This step also breaks down oxygen attached to the oil, which might lower oil quality. Hopefully, after all of this refining the oil is light in color, has no odor, no oxygen breakdown products and no solid wax. The amount of oil you have left after refining is related to the amount of crude oil you started with or to the amount of oil in the seed extracted by each step in the process
(in reply to blw)
       Post #: 582
RE: Castor oil - A final word? - 12/26/2007 12:50:44 AM
Flyboy Dave
Status: offline
....yes....all those descriptions of "processing" the oils are about oils other than castor.
Castor oil is not "refined" like almost all the other types. Again, I'm starting to believe
that this de-gumming castor oil business has been because since it is in the vegatable
oil family, it is presumed to be "refined" like the othe oils.
The castor oil we use is squeezed (pressed), filtered (to get the husk debris out) and
put into a container to be sold....just that simple.
I think the "de-gummed" thing is just a marketing ploy to have us believe something
special has been done to the stuff. I could be wrong, but that is my opinion at this point.
FBD.
Revver Bro #4.
       Post #: 583
RE: Castor oil - A final word? - 12/26/2007 1:04:07 AM
skiman762
Status: offline
this throws a spin on it
Uses in early aviation and aeromodelling
Castor oil was the preferred lubricant for the early aviation powerplant design known as the rotary engine, such as the Gnome engines used in pre-World War I "pioneer aircraft", after that engine's widespread adoption for aviation in Europe in 1909, and was used almost universally by the rotary engines in World War I Allied aircraft.
The methanol-fuelled glow plug engines used for aeromodelling purposes, since their adoption in the model airplane hobby in 1948, have used castor oil as a dependable lubricant that is highly resistant to degradation when the engine has its fuel-air mixture "leaned out" for maximum engine speed. The aforementioned gummy residue problem can still be troublesome for aeromodelling powerplants lubricated with castor oil, however, usually resulting in eventual ball bearing replacement when the residue builds up too much within the engine's bearing races.
       Post #: 584
RE: Castor oil - A final word? - 12/26/2007 1:13:57 AM
Flyboy Dave
Status: offline
....the guy that wrote that last sentence obviously has never been an aero-modeler using
castor in his engines....
....a synthetic oil salesman probably told him that.
FBD.
Revver Bro #4.
       Post #: 585
RE: Castor oil - A final word? - 12/26/2007 3:23:21 AM
downunder
Status: offline
From http://www.castoroil.in/extraction/extraction.html
Castor Oil Extraction
Extraction of oil from castor seeds is done in a manner similar to that for most other oil seeds. The ripe seeds are allowed to dry, when they split open and discharge the seeds. These seeds are cleaned, cooked and dried prior to extraction. Cooking is done to coagulate protein (necessary to permit efficient extraction), and to free the oil for efficient pressing.
The first stage of oil extraction is pre-pressing, using a high pressure continuous screw press – called the expeller. Extracted oil is filtered, and the material removed from the oil is fed back into the stream along with fresh material. Material finally discharged from the press, called cake, contains 8 to 10 percent oil. It is crushed into a coarse meal, and subjected to solvent extraction with hexane or heptane.
Oil Purification
Once the oil has been extracted from the seed, it is necessary to remove impurities from the oil.
The oil is essentially a pure triglyceride, and contains almost 90% of glyceryl tricinoleate. It is the ricinoleic triglyceride that is needed in order to produce high quality castor oil.
The steps to refining the crude oil include:
* Settling and Degumming of the oil - Done to remove the aqueous phase from the lipids, and to remove phospholipids from the oil.
* Bleaching - Bleaching results in the removal of coloring materials, phospholipids and oxidation products.
* Neutralization - The neutralization step is necessary to remove free fatty acids from the oil. This can be done in one of two ways: (a) Alkali (Chemical) or (b) Steam Stripping (Physical) means.
       Post #: 586
RE: Castor oil - A final word? - 12/26/2007 4:41:59 AM
Flyboy Dave
Status: offline
quote:
FBD: I think the "de-gummed" thing is just a marketing ploy to have us
believe something special has been done to the stuff.
.....that's what I get for thinking (again).
....good one, Brian....
Revver Bro #4.
(in reply to downunder)
       Post #: 587
RE: Castor oil - A final word? - 12/26/2007 2:57:11 PM
skiman762
Status: offline
here are the first press grades of CASTOR OIL
1. Pale pressed grade castor oil is a form of castor oil that is characteristically clear and free from suspended matter. Light in colour and low in acidity, it is obtained from the first pressing of the castor bean.
2. First Pressed Degummed
Castor oil that is first pressed, filtered and then degummed has the unique lubricating properties of castor without the excessive buildup and carbon
Now I would have to say that clearly that castor oil goes through many different processes depending on it's intented use
I also think it's safe to say that ALL fuel blenders excludeing home brewers use First Pressed/Degummed castor
and that some choose to advertise it that way in hopes that a custumer will be swayed to their product when in fact all blenders are useing the same grade of oil
       Post #: 588
RE: Castor oil - A final word? - 12/26/2007 4:48:43 PM
jaka
Status: offline
Hi!
So...what do say Castrol M is...degummed Castor or not??
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
       Post #: 589
RE: Castor oil - A final word? - 12/26/2007 5:02:39 PM
skiman762
Status: offline
Complete List of Castor Oil & Castor Oil Derivatives
l
Castor Meal
Hydrogenated Castor Oil (HCO)
12 Hydroxy Stearic Acid (12 HSA)
Methyl 12 HSA (Hydroxy Stearate Acid)
Blown Castor Oil
COLM (Urethane Grade)
Commercial Grade
BP
DAB-10
Deodorized
European Pharmacopia
Extra Pale Grade
Pale Pressed Grade (PPG)
Special Grade (First Special Grade (FSG)
United States Pharmacopia (USP)
Industrial Castor Oil
Dehydrated Castor Oil (DCO)
Ethoxylated Castor Oil
Ricinoleic Acid
Methyl Ricinoleate
Sebacic Acid
2-Octanol
C 3
Glycerine
C-7
Heptanoic Acid
Heptaldehyde
Heptyl Alcohol (Heptanol)
C 11
Undecylenic Acid
Undecanoic Acid
Undecylenic Aldehyde
Undecylenic Alcohol
Calcium Undecylenate
Zinc Undecylenate
Allyl Undecylenate
Sodium Undecylenate
Methyl Undecylenate
Ethyl Undecylenate
C 18
Esterols
(in reply to jaka)
