Flyboy Dave
CA, USA Status: offline
quote:
ORIGINAL: Steve Campbell <<...mass quantities of oil...>> I understand that, Dave. But if the smoke isn't the by-product of combustion (i.e., burning), what is it??? . The smoke is, of course, the oil burning. The only synthetic oil that does not "burn" (to my knowledge) is Klotz. Klotz oil is a butyl gas in a liquid state. It does not burn....when heated to a certain temp....it goes poof.... ....right back into a gas. Gone. If your fuel is pink, you probably have Klotz in it. Sometimes you can see a pink tinge from the dye in the Klotz on your plane....but you will not see the oil....it is floating away somewhere ! If you were burning the synthetic oils at 1, 2, 3, or 4 %....they way they were designed, you would be hard pressed to see any smoke. If you looked closely you might see a slight haze at full throttle. Why full throttle ? Because that is when the most fuel is being burned....the oil is going along for the ride. FBD.
< Message edited by Flyboy Dave -- 6/2/2004 1:45:19 PM >
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
