ini
quote:
ORIGINAL: Sport_Pilot ini, You have several things wrong. 1. The issue that synthetic oil has less friction is a bit of a myth, it is thinner which makes it more slick at room temperature, but it also has a better viscosity index, that it it thins out less at high temperature, like 300 degrees or so. But castor is thicker and also has a high viscosity index, higher than mineral oil, but lower than synthetic. Still I suspect castor oil is slightly thicker at operating temp, which gives synthetic an edge on friction. But on lean runs castor oil breaks down into an even thicker oil which gives it an edge on protection. The varnish is an advantage also, but pure castor oil builds this varnish up a bit too rapid, requiring occasional cleaning of the inside of the engine. Also there has been great advance with synthetic oils, but only with those oils used in gas and turbine engines. We are using the same synthetic oils invented 30 years ago. I understand there are some new oils in Europe but it remains to be seen that they are truely a superior oil, or that they are enviornmentally safe. If they are using similar oils as jet turbine oils they may be harmful to your health. Hey guys, use what ever oil you like. I'll do just the same here The low friction with Aerosave/Aerosynth2 & Motul Micro compared to Castrol M & Klotz Benol is not a myth. It is a tested fact. I do not know how much the readers of this know about tribology but I have tested it myself using correspondent surface pairs used in modern motors. I can tell you that castor has no change. I should have kept a friends messed YS 120 AC that had its piston seize. The piston actually fractured and broke into two pieces. The fuel was degummed castor 20% + 10 % nitro, rest methanol. The reason, however was not friction. The regulator got clogged and it lost all lubrication just like that when full power was applied. The owner of that engine never used castor again. The diaphram itself was not harmed, but there are tiny little passages in an YS that got clogged. Maybe it would be a good idea to add a drop of castor or two in running in phase. With synthetic running in takes ages as surfaces wear so little. ini PS. Secret: (do not tell anyone) that no power on earth thing was sort of a joke But maybe that environmental side of castor has to be given some thought
