RE: Castor oil - A final word?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Castor oil - A final word?
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Castor oil - A final word? - 6/14/2004 2:13:22 PM
jessiej
Status: offline
[This is what I like to see. No rust, crud or burnt anything. Just clean, shiny, metal coated with oil-- the way an engine should look]
That is the way my engines look. BS- all run with castor. I can't imagine what you fellows who have problems with castor are doing wrong. Perhaps there is some common factor that will provide a clue???
jess
(in reply to Boomstriker)
       Post #: 151
RE: Castor oil - A final word? - 6/14/2004 2:33:14 PM
DarZeelon
Status: offline
Jess,
Anyone who has had any problem with Castor oil, has been running a medicinal (sugar added) grade, or another type of non-degummed Castor.
With Klotz BeNOL, Morgan CleanCastor, Baker's AA (Sig), Model Technics (UK), or other brand of first press, degummed Castor oil; will only have the hot sections (combustion chamber and exhaust port) with an appearance of anodized brown.
The rest of the engine remains clean.
Castor oil is still the best and most protective lubricant and everybody is trying to find a replacement for it.
Someday maybe they will.
I always use some Castor oil (8.5-11%) in my lubricant package.
I don't own any YS engines...
Yet...
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to jessiej)
       Post #: 152
RE: Castor oil - A final word? - 6/14/2004 2:52:16 PM
Sport_Pilot
Status: online
Sadly not any I have taken, though not sure it would help the taste. Lemon juice helps though.
IMO degummed is a myth. Blown oil used for paint will gum and dry. First press oil is thinner and has less impurities.
< Message edited by Sport_Pilot -- 6/14/2004 10:02:02 AM >
(in reply to DarZeelon)
       Post #: 153
RE: Castor oil - A final word? - 6/14/2004 3:12:13 PM
DarZeelon
Status: offline
Hugh,
All probably true.
But some Castor oils are "considered" to be degummed and are first press and clean running.
I encountered Castor oil which seemed to have Caramel in it...
(in reply to Sport_Pilot)
       Post #: 154
RE: Castor oil - A final word? - 6/14/2004 3:35:47 PM
Sport_Pilot
Status: online
Blown oil of oll poorly stored oil will be darker in color. Our castor oil will not dry or oxidize readily in paints. By blowing air at high temperatures the oil partialiy oxidizes and an H2O molecule is peeled off and it becomes a drying oil. As a drying oil it will gum and harden readily. There is no gum acutally removed from castor oil as I know of. I think some manufactures have removed the term degummed. Medical and cooking castor oil is tested for traces of ricien poisen.
       Post #: 155
RE: Castor oil - A final word? - 6/14/2004 4:08:23 PM
Boomstriker
Status: offline
Bill, that is the remainder of a 3x5 card cut muffler gasket.
Motorbrain--Yes, it does look like a new one doesn't it-- It's only 4 1/2 years old and 5+ cases of Coolpwer and WildCat 100% synthetic. It has a gold spot on top of the piston that wipes off easily.
Jim-- exactly, acidic conditions do promote rusty steel. Hygroscopic fuels promote moisture and more rust but the aluminum will still shine. I like my steel to shine too.
Sport pilot- I know a rusty bearing when I see, hear and feel it. With your comments on how our clean, shiny synthetic oiled bearing is really rusty, and a 'gravely' sounding Castor bearing that looks like these really isn't rusty, you obviously don't have a clue.
Except for a two or three bushed engines and a couple new ones, I've had to replace the bearings in all my engines run on castor at least once.
Here's just a few:
1- TT.46, 8 years old, many cases of fuel, two sets of bearings
2- TT 120, 10 years old, two sets of bearings.
3- OS 46FX's, one 3 years, other 7, lots of fuel, older has had bearings replaced, both need it again.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to William Robison)
       Post #: 156
RE: Castor oil - A final word? - 6/14/2004 4:18:07 PM
Sport_Pilot
Status: online
I didn't say the bearing rusted, just worn out from poor lube, or just a poor bearing after about 6 months. If you are talking about the congealed oil on bearings, especially ones that have been stored for a long time, you are looking at the geled oil, not rust, you have been unnecessarily replacing oil. I don't know what you been by 'gravely' unlest the bearings are making gostly sounds, but sometimes the bearings can get stuck when sitting a while, just flood the engine with fuel, let it sit and the castor oil will dissolve. If you use the engine continously it will not congeal and look much as Will Robinson has shown.
       Post #: 157
RE: Castor oil - A final word? - 6/14/2004 4:21:21 PM
Sport_Pilot
Status: online
Those bearings look good to me, wrong color for rust. Hard to say though, you would have to clean off the castor to be sure. Same for the crank, looks as though it was stored for a time.
       Post #: 158
RE: Castor oil - A final word? - 6/14/2004 4:47:09 PM
Boomstriker
Status: offline
1- ST GS40, 4 years old, only 10 flights and not even broke-in, bearing rusty and noisy.
2- Saito FA.72 new with only 1.5 gallons of break-in, surface rust on bearing races already.
3- LA40, 3 years old, no bearings but lots of rust.
4- same .72 exhaust valve, lots of build-up already, no wonder they stick after a few gallons.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Boomstriker -- 6/14/2004 7:17:05 PM >
       Post #: 159
RE: Castor oil - A final word? - 6/14/2004 5:04:43 PM
3d-aholic
Status: offline
My dad gave me a few CL motors once that he used when he first flew...they were about 40 years old at the time. They only had Castor really back then. They were completely frozen. Took them apart and cleaned them. The castor was a light to dark brown color gel plastic that had turned into the color of dried varnish in the bottom of an old paint can. The stuff was hard as plastic. After 24 hours in alcohol, cleaned up real nice...NO RUST! The alcohol was brown rust colored.
I don't believe you should see much rust with any kind of "oil" though...castor or synth unless your motor is sitting out in the rain. Oil is aliphatic and hydrophoebic. A motor with 10 flights and broken bearing, an engine with 1.5 gallon of fuel, can't be blamed on any oil....or any fuel. You have to be doing something else extraneous to be destroying your engines. No engine is made that can sit at the bottom of your pool for the season.
Hovering takes the Edge OFF.
       Post #: 160
RE: Castor oil - A final word? - 6/14/2004 6:04:32 PM
Sport_Pilot
Status: online
Where's the rust? Rust is red not brown!
       Post #: 161
RE: Castor oil - A final word? - 6/14/2004 6:07:00 PM
Sport_Pilot
Status: online
Again this is the wrong color for rust. Rust when removed with a solvent leaves the solvent the color of red clay, though mixing with motor oil and dirt can turn it reddish brown.
       Post #: 162
RE: Castor oil - A final word? - 6/14/2004 6:18:40 PM
3d-aholic
Status: offline
quote:
ORIGINAL: Sport_Pilot
though mixing with motor oil and dirt can turn it reddish brown. EXACTLY!
I don't want to get in to a symantic discussion about the color of rust. It looks reddish-brown to me though. When I think of red, I think of Old Glory Red...and that it ain't. Anything close to brown in my book, is brown. And rust is the oxidative process of steel. Besides the screws, the glow plug and a few odds and ends...there is virtually NO significant amounts of steel in a glow motor. The oxidative process of Aluminum turns the aluminum from shiny to dull...so the color is grey/black. And, in that case, I see aluminum oxidatation (AL rust) and pitting in virtually every picture here.
       Post #: 163
RE: Castor oil - A final word? - 6/14/2004 6:21:44 PM
3d-aholic
Status: offline
Why do you people get so worked up over your $150-$300 motors anyway....? My planes crash way before these motors ever get black...
(in reply to 3d-aholic)
       Post #: 164
RE: Castor oil - A final word? - 6/14/2004 6:22:54 PM
DarZeelon
