Boomstriker
Joined: 1/15/2002 From: New Haven , MO, Status: offline
I don't argue that Castor offers good protection from lean runs. But I've never had an engine damaged from a lean run, whether it had a diet of Castor it's entire life, synthetic it's life, or broke-in on Castor and running on synthetic. My problem is rusty bearings on Castor engines that don't get run very often. I wish I had the time to fly all of them every other week to keep them lubed. Maybe those of you that remove your engines and put them in moth-balls for the winter are the ones that don't have rust issues. I'm not sure what you guys are seeing in the pics, but there is no oxidation or corrosion on the aluminum in any of my engines. Oxidation is white and powdery in dry, and pasty in a moist environment with lots of pitting in the aluminum. These are clean and shiny with no pits at all. Some of you state that this brown crud is the Castor build-up that protects the metal, but no one can explain why the ferrous crank and bearings are loaded, yet the all the aluminum, including the rod end is spotless. Does the Castor have a preference as to what it sticks to? If the build-up IS the protection, how does it stick to the spinning balls and races that need the most protection? Because of the build-up on the hot muffler, some may say the temperature of the surface has a lot to do with what the Castor 'cooks' to. I would have to argue that with the fuel and air flow through it, the crank only gets warm, and certainly not any hotter than the rod. Maybe the Castor thats 'cooked' on the 600* aluminum muffler is different from what 'sticks' to the 180* steel crank? Others say that this metal would be shiny, smooth and like-new after being cleaned. I don't argue that the majority is build-up from Castor, but when it is cleaned away, my metal is not clean and shiny, it's dull, lightly pitted and full of surface rust. Only some work on a belt sander would get the crank looking like new, or like the first pic of the old synthetic engine. The point is, by what I see when I pop the cover, regardless of what color it is, I'm convinced that rust is the cause of my many noisy bearing over the years. I have a large hanger and don't have the time to remove, strip, soak, clean, oil and bag each engine every year. Hell, most of the time, I don't have time to clean the planes or get some after-run in the things at the end of the day. And if I don't, it's forgotten by the next week. So far, the synthetic seems to be protecting from rust much better with my bad maintenance habits. If I have a melt-down while using it, I'll post it, but with the lean runs I've had so far, I can't complain 'cause it seems to be protecting there too. Kirk
