Mr Terminator
Joined: 11/14/2007 From: Manchester, UNITED KINGDOM Status: offline
I use an Ofna Filter/primer with the stone filter removed for the pressure regulator on my Genesis truck as do a lot of GST guys.The primer acts like a non return valve and stops the leaning issues you get at half tank on the Genesis as they have 220cc tanks.I guess the same filter/primer would do the same job on any system that requires even pressure,some call it the Checkvalve mod and it really is a good mod on the GST/Genesis....
_____________________________
Hopped up HPI Baja SS,Hopped up HBX VRX-2 Pro,Standard VRX-2 Pro,TTR ST-1,TTR Hammer 18S,CEN Genesis LE & MG16,Acme NB16T
