Idle-needle in RB-engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Idle-needle in RB-engine Page: [1]
Login
Idle-needle in RB-engine - 6/2/2004 8:09:35 PM
3240
Status: offline
Im going to adjust my idle-needle on a rotary carb and i read this at the faq at RB hompage:
quote:
the idle-needle must be turned in totally(be sure you position the slide in the open position before you do this, so you do not damage or block the needle in the spray-bar) and then open again 2.5 turns. "
Should i open the throttle, then turn the idle-needle in (clockwise) untill it stops, then turn it out (counterclockwise) 2,5 turns ?
If i do this the idle-needle will hit the spraybar when im closing the throttle.
Wouldnt it be better to adjust the needle when the throttle is closed?
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU3
