RE: BEST CRAWLERS OUT THERE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: BEST CRAWLERS OUT THERE
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: BEST CRAWLERS OUT THERE - 2/19/2005 5:49:56 AM
Balact Man
Status: offline
the two of these trucks have Novak powerplants- TXT-1 running the HV and TLT-1 running the 5800. my only problem is with the TLT-1 every time i pull the trigger the front wheels spin like krazy.
_____________________________
If Anyone Gives You Problems, Let it Ride
(in reply to Balact Man)
       Post #: 51
RE: BEST CRAWLERS OUT THERE - 2/19/2005 6:37:55 AM
badtodabone
Status: offline
i would like to buy that truck,thrash it, and send the builder pics of it beat to crap
My Crawling Site
www.rockpunisher.com
       Post #: 52
RE: BEST CRAWLERS OUT THERE - 2/19/2005 9:10:47 AM
Tom_Braider
Status: offline
quote:
ORIGINAL: garynjr
You can actually run a motor under water.
Not for very long.
An unsealed motor would develop a number of problems:
- rust and corrosion when you return to air
- break-down of anything water-soluable fibre insulators (if any)
- voltage leak in anything other than de-mineralized water
- leaching of lubricants
- attacks by large octopuses
Okay, I made that last one up.
(in reply to garynjr)
       Post #: 53
RE: BEST CRAWLERS OUT THERE - 2/19/2005 5:07:52 PM
pinkfloydman
Status: offline
really?!?!? sweet i guess i odnt have to worry about octopuses then........and on that TXT the body is WAY WAY WAY to high, other than that, cool
(in reply to Tom_Braider)
       Post #: 54
RE: BEST CRAWLERS OUT THERE - 2/20/2005 12:37:15 PM
RC-Archer
Status: offline
Some of the R/C submarine kits that you can buy, have "wet" motor systems. Meaning that the motor runs under water.
       Post #: 55
RE: BEST CRAWLERS OUT THERE - 2/20/2005 2:31:07 PM
Cummins
Status: offline
quote:
ORIGINAL: Balact Man
Have you locked the diffs? I don't have a TLT-1 but apparently that just makes it wheely rather than spin.
A while ago my account was hacked.
If you know anything about this,
       Post #: 56
RE: BEST CRAWLERS OUT THERE - 2/20/2005 3:03:19 PM
AddictedtoRC
Status: offline
You must lock all 3 diffs on the tlt-1 if you want it to crawl at all
Savage SS ,custom clodbuster
Nitro Evader ST
(in reply to Cummins)
       Post #: 57
RE: BEST CRAWLERS OUT THERE - 2/20/2005 6:54:59 PM
Bombers_410
Status: offline
omg ive never seen those rock crawlers before! those look totally diffirent from any ohter rc truck. how much does it cost to convert to one of those?
LX Comp, Pede, Shark. Join the club
My IQ: 135
(in reply to AddictedtoRC)
       Post #: 58
RE: BEST CRAWLERS OUT THERE - 2/20/2005 11:41:38 PM
Balact Man
Status: offline
quote:
ORIGINAL: Cummins
well funny you should mention locking diff's and all. i locked the txt-1 with bubble gum and it works great. however the tlt-1 has the strangest center diffs i have never seen before so i'm not sure how to lock the center diff. until i figure it out locking the f/r diff won't solve my problem..........
< Message edited by Balact Man -- 2/21/2005 9:11:14 PM >
       Post #: 59
RE: BEST CRAWLERS OUT THERE - 2/20/2005 11:57:50 PM
fitzy121
Status: offline
the center diff on the TLT is a ball diff i think, but you can lock them by tightening the diff up till it locks worked for me .
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 60
RE: BEST CRAWLERS OUT THERE - 2/21/2005 12:04:33 AM
fitzy121
Status: offline
check out pic to lock center diff on TLT
Click for fullsize
(in reply to fitzy121)
       Post #: 61
RE: BEST CRAWLERS OUT THERE - 2/21/2005 12:21:08 AM
Balact Man
Status: offline
quote:
ORIGINAL: fitzy121
fitzy what you are saying is to screw it as tight as i can get it then put it back in and the center diff will be locked for action? is your truck diff's locked? please let me know. lastly, you picked one of the best color schemes i have ever seen on any tlt-1 truck. great job!
       Post #: 62
RE: BEST CRAWLERS OUT THERE - 2/21/2005 3:09:35 PM
garynjr
Status: offline
Balact Man, I would not recomend bubble gum to lock your diffs. and also if you do a search on locking the diffs on your TLT you will find there are many threads on that here.
You shouldn't just screw it down hard beause you will just strip it anyway. Some people use small screws to screw the plats together or you can use jb weld or Hot glue. Just be sure that it is even and ballanced. You should lock your front nd rear diffs by using the method where you take one of the cone type gears and flipping it to the other side. It's listed somewhere in the Rock crawling section. do some searches... Hope that helps...
Life is too short! Play hard!
Rs4 3 SS, OFNA Ultra LX Comp
       Post #: 63
RE: BEST CRAWLERS OUT THERE - 2/21/2005 6:08:19 PM
Cummins
Status: offline
Fitzy that is one mean TLT!!!! How much money went into that? I was thinking of getting one but that looks like £500 upwards!
EDIT: No cussing please. Thanks. // Studysession
< Message edited by Cummins -- 2/21/2005 10:09:17 PM >
       Post #: 64
RE: BEST CRAWLERS OUT THERE - 2/21/2005 9:09:31 PM
Balact Man
Status: offline
quote:
ORIGINAL: garynjr
garynjr thanks for the information this will help me a great deal. fitzy i was thinking why don't we just trade trucks so i don't have to go thru all this LOL.
       Post #: 65
RE: BEST CRAWLERS OUT THERE - 2/21/2005 9:50:19 PM
screwloose
