Looking for a pattern plane for 1.20 2 stroke engine and pipe.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Looking for a pattern plane for 1.20 2 stroke engine and pipe.
Page: [1]
Login
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/8/2002 8:55:37 AM
poorbs
Status: offline
I'm interested in moving up to a 1.20 size airplane, but don't want to get into an equipment race with a composite fuselage, plug in wings, etc. I've been flying a .60 Boxer and like it's simplicity and all balsa/foam construction. Is there an all balsa/foam airplane out there I don't know about for 1.20 2 stroke? What about a 2 meter Boxer? Any suggestions would be appreciated. Thanks
       Post #: 1
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/8/2002 9:32:04 AM
dgrant
Status: offline
How about a Zen120. That actually sounds racey, and the Zen family of planes is very decent.
(in reply to poorbs)
       Post #: 2
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/8/2002 9:50:49 AM
poorbs
Status: offline
DGrant - thanks for your reply. I just checked out the Zen 120 on the World Models website, and it seems to be designed for a 1.20 4 stroke. My experience has been that the pipe tunnel may be too small for the 1.20 2 stroke pipe, and require modification of the fuselage - a problem with ARFs . I guess what I'm looking for is a plane designed for the 1.20 2 stroke engine and pipe.
       Post #: 3
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/8/2002 11:22:45 AM
dgrant
Status: offline
I think your right. I don't recall seeing the bigger Zens running anything but 4-strokes. Oh well The thought is kind of entertaining though. The planes do handle real well. If I see anything else that's interesting though, I'll report back to your thread here. Good luck. Also, if you find something post it back here. I'd be interested to know whats out that is a decent 2-stroke 120 bird.
       Post #: 4
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/9/2002 12:31:56 AM
BPKlein
Status: offline
Take a look at the Aeroslave Entropy.
home.attbi.com/~aeroslave/
It is a modified version of the Prophecy, but lighter. Aeroslave is also local to you and me. There are a couple of them going together in the Dallas area. At 9.5ish pounds a 1.20 2 stroke will pull it fine, and the pipe tunnel is large enough for a 2 stroke pipe.
Bryan
Dallas, TX.
       Post #: 5
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/9/2002 4:36:09 AM
GMM
Status: offline
poorbs
You wouldn't happen to have a set of plans for the Boxer 60 you would like to sell? I have been wanting a copy, but they are not available anymore.
As for the 120 sized airplane, if you are into scratch building, the Gator Typhoon 2000 is all wood, and can be powered with a 120 2 stroke.
I'm finishing up a Fivol II which is an early 90's design pattern plane with a one piece wing, and designed for a 120 4 stroke. I'm putting a Bully 120 2 stroke in it, and had to make extensive modifications to get the pipe to fit. It was not easy, but do-able.
Greg
       Post #: 6
pattern plane for 120 2s - 7/9/2002 7:09:25 AM
Newton
Status: offline
Bob Pastorello has modified the EMC2 to run the Super Tigre 2s. At one time he had quite an extensive series of how toos on his website. That would be Oklahoma Pattern but i don't know the exact address.
       Post #: 7
GMM - need email address - 7/9/2002 10:29:52 AM
poorbs
Status: offline
GMM,
I've built 2 Boxer 60s and probably have a set of plans around somewhere. Send me an email so I'll have your address - I couldn't access it through R/C Universe.
Thanks, Bill
       Post #: 8
I'd be interested in copies as well. - 7/9/2002 10:04:14 PM
Pugsley-RCU
Status: offline
Want to sell on of the Boxer's?
Pug
       Post #: 9
Pug - 7/9/2002 10:44:16 PM
poorbs
Status: offline
Pug, I wish I could help you out, but my first Boxer met with an untimely end and I'm currently flying the second as my main pattern plane.
I think someone with a flair for business and R/C needs to pick up where Gus left off and continue with the Boxer line of airplanes. I'd buy a 2 meter Boxer in a minute. I still have a 120 Boxer all cut out and ready to build - I just have to get around to it. It's designed for the 120 4 stroke engine though, and the pipe tunnel is too small for the 2 stroke pipe. I guess I'll just have to build it and make the necessary modifications.
Keep your eye on eBay - I've seen several Boxers there over the last couple of years.
Poorbs
       Post #: 10
2 METER SHIP - 7/9/2002 11:19:21 PM
TOYMAKER
Status: online
Hey poorbs... or is that Bill to us in the know?
I got a 2 meter Prophecy that I will sell you as soon as I finish my new ARIES. Or how about a new carbon fiber Entropy. I could build it up for you to the ARC condition for $600.00 including a soft mount. Think about it.
Wayne
Click to see fullsize image.
Click for fullsize
< Message edited by TOYMAKER -- Jul 9 2002 6:24PM >
       Post #: 11
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/10/2002 1:26:56 AM
jabowil-RCU
Status: offline
I've seen something recently from Joe Bridi on a 2 meter kit. Don't have the web address but I'm sure you can find it.
       Post #: 12
Looking for a pattern plane for 1.20 2 stroke engine an... - 7/10/2002 4:59:03 AM
GMM
Status: offline
poorbs,
Sent you an email.
Greg
       Post #: 13
Pattern Plane - 7/10/2002 7:18:20 AM
edwarda10pilot
Status: offline
Jobowil:
Joe Bridi's address is: [URL=www.bridiradiocontrol.com]www.bridiradiocontrol.com[/URL]
Toymaker and Poorbs:
Are there any upconing pattern events in the Dallas area. I'm in Seagoville (near Mesquite). I flew pattern in the 80's and early 90's and then got out. Thinking about getting back into pattern. I am in the process of building a Conquest 6 for an YS 60FR that I have NIB (old short stroke 2c) just to fly around. I have also started an SL 1 that I found NIB a few weeks ago. WOuld like to put my YS 120 in it. Any thoughts on whether to make the planes fixed gear tail draggers or put retracts in it.
Ed
       Post #: 14
Dallas area pattern events - 7/10/2002 8:07:43 AM
poorbs
Status: offline
Ed,
Thanks for your reply. I have my calendar marked for August 24-25 for a contest in New Waverly (near Houston), Sept. 14-15 in North Dallas, August 27-28-29 in Lubbock. I hope to make the New Waverly and North Dallas contests - I'll have to wait and see on the Lubbock event. Check the AMA rag for details.
I checked out the Bridi 2X2 Dirty Birdy on his website, and it looks like he's simply upscaled an older design. I flew an Escape in competition back in 1994, and it had a few flight characteristics I wasn't crazy about. I went from that to a Boxer 60 and wow, what a difference. If he had a "new" design - something with some of the more recent (1990s at least) flying refinements - I'd go for it. The designs from the 70s flew great - back then - but they've been eclipsed by more recent designs.
Anyway, thanks for the lead.
Bill
       Post #: 15
