RetUSAF
Joined: 6/20/2002 From: Vancouver (not B.C.), Washington (not D.C.) Status: offline
I put together one a couple of weeks ago, works great for the ST. However: I would NOT tie 5 v to 12v!! I would wager that 6 A will work for most charging situations, as long as you aren't charging huge batteries. That said, I would suggest going to your local computer store, explain what you are doing, and ask if they have an AT power supply in their junk bin. My local store gave me one--free-- (Thanks, Wintech!!), that the tech even checked it out. 9 A @ 12 v....For that price, why risk using an underpowered PS?? The AT power supply isn't compatible with current motherboard designs, but it works great for this use. Just tie all the yellow wires together (+12v), all the black ones (ground), and the red ones if you want 5v available too. I cleaned up some of the other wiring (clipping, wrapping, ties), just pay attention to where the 110 stuff goes...I added a couple of banana jacks, and placed an on/off switch in line with the 110 v lead to the circuit board (got rid of the original computer push button.) I also added a 10 ohm, 10 watt wire wound resistor across the 5 volt leads ($1.69 for 2 at Radio Shack). Actually, I just plugged it into the mini-drive plug, red and black, and it increased my voltage at the 12 v side from 11.2 to 11.7v I think..... Hope this helps. Doug
