RE: Any scratch builders out there? Post pictures!
Tower Hobbies
Logged in as Guest
  Printable Version
Radio Synthesized Module & Receiver - RTF
Seller:  Roger Shipley
Details:   $155.00   |  11/20/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Any scratch builders out there? Post pictures!
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Any scratch builders out there? Post pictures! - 6/22/2004 5:07:40 AM
rcairplanenut
Status: offline
nice
What do the molds look like?
SGG
(in reply to TGoodwin)
       Post #: 101
My little Norvelian Star Cruiser - 6/23/2004 4:17:58 AM
phuffstatler
Status: offline
Well, it's an older one, but here's a little design I did last year, some of you from the 1/2A forum might have seen....
phil in austin
Click to see fullsize image.
Click for fullsize
< Message edited by phuffstatler -- 7/6/2004 4:07:29 PM >
_____________________________
http://philhuffstatler.com
"I love the smell of glow fuel early in the morning..."
(in reply to rcairplanenut)
       Post #: 102
RE: Any scratch builders out there? Post pictures! - 6/23/2004 6:38:31 AM
William Robison
Status: offline
Phil:
Hadn't commented on it before, but I think it's a shame when your transmitter costs ten times what the plane does.
Haw.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to phuffstatler)
       Post #: 103
RE: Any scratch builders out there? Post pictures! - 6/23/2004 3:07:19 PM
phuffstatler
Status: offline
But it's the only one I have!!!!
Well, no, take that back. I do keep a Futaba 6XAS around as backup and for park flying with my Shock-Flyer.
phil in austin
(in reply to William Robison)
       Post #: 104
RE: Any scratch builders out there? Post pictures! - 6/23/2004 3:48:26 PM
acr007
Status: offline
In responswe to Andre,
Andre, Show me more! I really like that Hawk!
Bigger Badder Meaner Faster!
Revver Brotherhood #41
Hwere is my latest scratch build and plan modified to suit IC from electric plus a feew other mods of my design.
Click for fullsize
Click for fullsize
(in reply to vicman)
       Post #: 105
RE: Any scratch builders out there? Post pictures! - 6/23/2004 4:41:02 PM
rcairplanenut
Status: offline
Hi Dick,
Do you have a CAD system on your computer?
I do all my designs on CAD anymore, it helps me a lot
SGG
(in reply to acr007)
       Post #: 106
RE: Any scratch builders out there? Post pictures! - 6/23/2004 6:27:30 PM
dicknadine
Status: offline
I do-- but DUH, sure don't know how to use it. am still of the old ruler/compass school. at almost 80 yrears young, its rough to comprehend this new stuff. beginning to figure out photo attachments. besides if I did use one, I still couldn't print it on the desk top printer. also believe my eraser is quick enough. thanks anyhow. dick
       Post #: 107
RE: Any scratch builders out there? Post pictures! - 7/2/2004 9:19:10 AM
acr007
Status: offline
My first design of my own, but needs to be refined. For a start fuse is to big so will use smaller fuel tank and reduce the fuse by 3/4" to make it more stream lined. I call it simple jet.
Click for fullsize
Click for fullsize
(in reply to dicknadine)
       Post #: 108
RE: Any scratch builders out there? Post pictures! - 7/2/2004 10:16:27 AM
Darrinc
Status: offline
Here is a different way to scratch build. I started with a large foam block and some CAD DWG's that a friend and myself made. I plotted out the top and sideview, then made templates to hotwire the foam, then did all of the contouring by hand.
This will be a plug that I will pull a mold off of and then layup the actual plane.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Darrinc -- 7/2/2004 2:17:57 AM >
"Make everything like your going to make the front page of NASA Tech Briefs"
Go Team Orange! Darrin R Cash
       Post #: 109
RE: Any scratch builders out there? Post pictures! - 7/2/2004 3:44:21 PM
dicknadine
Status: offline
I have using foam as a plug for awhile, I then laminated balsa strips. 1st layer length wise, then next 2 layers at 45 degrees and final length wise. its strong and smooth. almost any contour can be fabricated this way. the attached is an original 81" design by a friend and it sure flys good. dick
Click for fullsize
(in reply to Darrinc)
       Post #: 110
RE: Any scratch builders out there? Post pictures! - 7/2/2004 4:10:48 PM
Spastic
Status: offline
here are a couple of my babys, you can see i like profiles, all my designs
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 111
RE: Any scratch builders out there? Post pictures! - 7/4/2004 5:57:03 PM
rcairplanenut
Status: offline
I like the twin boom thing
(in reply to Spastic)
       Post #: 112
RE: Any scratch builders out there? Post pictures! - 7/4/2004 6:07:59 PM
rcairplanenut
Status: offline
Here are a few more of my designs
SGG
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to BMatthews)
       Post #: 113
RE: Any scratch builders out there? Post pictures! - 7/8/2004 12:39:43 PM
Darrinc
Status: offline
quote:
ORIGINAL: dicknadine
What thickness and what density of balsa are you using? What are adhesive are you using between the layers?
With four layers you could probably use 1/32", 4lb contest balsa up to 35%.
Wow, great idea!!!
