CG question for semi-wing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> CG question for semi-wing
Page: [1]
Login
CG question for semi-wing - 7/10/2002 2:29:40 AM
wsmalley
Status: offline
Have an Altech Pilatus Porter,ST.61 with heavy prop extension shaft to get prop out on that long skinny nose. Has 6' ws with 10" chord semi-symmetrical wing. Plans call for CG to be about 1/2" behind LE. Plane flies ok but little elevator authority, made some pretty hard landings. I'm running a Futaba PA1 autopilot and with it on, plane still drops nose in a turn-have to feed in a lot of elevator. My flyin' bud thinks it's way to nose heavy and I agree. He suggests starting at 25% which happen to be right on line with the strut mount points. At that balance point, I stuck 2 oz. of lead in the tail to balance. Any how with a high wing semi, what's a good balance point to start with?
_____________________________
If I die, and I have the most toys, what do I win?
       Post #: 1
CG location - 7/10/2002 7:38:15 AM
florida817
Status: offline
I think your flying buddy is right on the mark. Most conventional planform aircraft balance between 25% and 33% of the Mean Aerodynamic Chord (MAC). If the Porter has a straight wing with a 10" chord and no taper or sweep, a good starting balance point will be 2.5" aft of the LE.
You're seeing all the classic signs of a CG that's too far forward in the flying qualities of the Porter. I feel sure that you'll enjoy flying the airplane a lot more with a CG location that's further aft.
Tom
(in reply to wsmalley)
       Post #: 2
CG question for semi-wing - 7/11/2002 5:45:31 AM
JERRY RCIA
Status: offline
I start out balancing all of my planes at the 30% mark and adjust from there to suit my taste. I'm currently flying a sport plane which is balanced at 35% and it is very tame but very aerobatic. I will say that, I've never moved the CG forward from 30% point on anything I've tried...................Jerry
       Post #: 3
CG - 7/11/2002 6:37:15 AM
wsmalley
Status: offline
O.K. guys, if the weather holds I'll try tomorrow, starting with 25% at 2.5" and go from there. I'm not good enough to fly something with a CG too far to the rear, so I'll start conservatively. I wound up with 2 oz. of lead in the tail to balance on 25% even with the elevator and rudder servos in the tail. I'm sure the large adapter I made to extend the shaft threw the weight forward from the plans, which did not call for such a thing.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.423RCU2
