pythonfan
FL, USA Status: online
quote:
ORIGINAL: SportsFans Thanks rcnitrohead, This is what it looked like earlier today, the axel nut that holds the 23mm hex adapter on keep coming off. So after the 3rd time I gave up. All fixed now, and all cleaned up. Hey pythonfan I took it throw everything today, dirt, tall grass, rocks and stone no damage at all. Funny you should ask, but I think I'm running the same flywheel you are the Associated Monster GT 3-Shoe Vented Flywheel with the Dynamite Max-life shoes. I'm also running the OFNA Pilot nut, which the spring fit in perfectly. Oh the shoes are trailing. Everything is locking up perfectly now . ThunderbirdJunkie it's plastic crafting film, pretty strong, and also sticky on the one side. I just peel it back when i have to remove the tire, then just stick back. It sticks back as good as the first time. pythonfan mine sounds almost as good as yours! that's my engine setup right there, without the ofna nut tho i use the hpi, i had to run the shoes leading cause of hpi's nut. so i get a little extra pop but hey who doesn't like that? I'm still running the hpi pipe, the only thing i did to the pipe was drill out the stinger so its open now. want to get a new pipe tho looking at your setup or this. (well hpi took the link off there site, it was to a line of hop ups from a new company who was making a pipe just for the savage a nice upgrade pipe)
_____________________________
pt.1 http://uk.youtube.com/watch?v=Rids9ycMW2k pt.2 http://uk.youtube.com/watch?v=vCTWvrJc-RE
