RE: YS CLUB    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: YS CLUB Page: <<   < prev  77 78 79 80 81 82 83 84 85 [86]
Login
RE: YS CLUB - 12/24/2012 4:07 AM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
I am doing a buddy a favor and going to rebuild his 140L that has been sitting for a few years.
Any advice for a first-timer?
YS140 Sport Front Bearing
YS140 Sport Front Bearing Oil Seal
YS140 Sport Rear Bearing
YS140 Sport Diaphragm
Regulator Gasket
YS140 Sport Head Gasket
YS140 FZ Gasket Set
Should that about do it?
_____________________________
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to MRMcFarlandM)
       Post #: 2126
RE: YS CLUB - 12/25/2012 6:27 PM
nitro wing
Score: 125
Last Login: 5/23/2013
Status: offline
send it to YS, their service is good and not that expensive, and will be done right.
You can always inquire about cost with them.
Hide Signatures
(in reply to mike early)
       Post #: 2127
RE: YS CLUB - 12/26/2012 3:47 PM  1 votes
Cyberwolf
Score: 655
Status: offline
The 140 FZ and Sport are different engines than the 140 L is As to weather or not the parts will interchange I don't know, some will I'm sure.
Why not just get the correct parts from Central hobbies they have the 140 L listed, Plus I would also get a crankshaft ring and a cylinder ring which I don't see on your list of parts,
You will also need to leak check the valves and maybe lap them in or replace them for a no leak seal.
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to nitro wing)
       Post #: 2128
RE: YS CLUB - 1/9/2013 8:59 AM
brezel53
Score: 100
Last Login: 4/28/2013
Status: offline
@mike early: also check and replace the barrel seal, very important!
I have a 140L with a damaged (pre owner, some chips out!) and hardened barrel seal.
quite dangerous, it revs up with closed barrel, because of "leaking air".
To check for damages you have to unbuild it, if hardened the barrel feels "loose", with an intact seal it is smooth with a little resistance.
Wolfgang
< Message edited by brezel53 -- 1/9/2013 12:06 PM >
Hide Signatures
(in reply to robert)
       Post #: 2129
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
