RE: MICK REEVES SUPER REAPER BUILDING
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: MICK REEVES SUPER REAPER BUILDING
Page: <<   < prev  1 2 3 4 [5]
Login
RE: MICK REEVES SUPER REAPER BUILDING - 10/19/2004 3:12:20 AM
Countryboy
Status: offline
Salmonbug,
Isn't it like 4:00 AM there.
(in reply to Countryboy)
       Post #: 101
RE: MICK REEVES SUPER REAPER BUILDING - 10/19/2004 4:11:26 PM
SALMONBUG
Status: offline
it was 4 am yes
       Post #: 102
RE: MICK REEVES SUPER REAPER BUILDING - 10/19/2004 6:23:51 PM
SALMONBUG
Status: offline
to all of you building or flying reaper, see my new thread in the jet forum about reaper CG and flight controls throw
some interesting infos coming out there
http://www.rcuniverse.com/forum/m_2267572/anchors_2267750/mpage_1/key_/anchor/tm.htm#2267750
(in reply to SALMONBUG)
       Post #: 103
RE: MICK REEVES SUPER REAPER BUILDING - 10/20/2004 11:05:50 PM
SALMONBUG
Status: offline
my progress........
Click to see fullsize image.
Click for fullsize
       Post #: 104
RE: MICK REEVES SUPER REAPER BUILDING - 10/25/2004 12:32:01 AM
Smuttley
Status: offline
Quick question reapers
Have you sanded your canards to section or left square at trailing edge, I have been told that leaving square can reduce the chance of flutter?? I intend on leaving mine square any problems with this?
PS SALMONBUG looks good, like to see it with canopy on
       Post #: 105
RE: MICK REEVES SUPER REAPER BUILDING - 10/25/2004 5:25:18 PM
jetflyer
Status: offline
Smuttley,
Interesting post, I've had some flutter problems and have always finished off the trailing edge down to a sharp edge. Perhaps others might comment on how their canards are?
JR Gautreaux
_____________________________
FREE People Search - http://www.usapublicdata.com
(in reply to Smuttley)
       Post #: 106
RE: MICK REEVES SUPER REAPER BUILDING - 10/25/2004 5:28:57 PM
SALMONBUG
Status: offline
after having read a lot the aerodynamic forum for one year, it apear that the opinion around the "to round or not to round" is 50 procent each.
mine are rounded, but my canard is carrefully balanced and the hinge gap is sealed with tape
a bit more patience to see it with hatch and canopy, they are in the paint room
(in reply to jetflyer)
       Post #: 107
RE: MICK REEVES SUPER REAPER BUILDING - 10/25/2004 5:59:20 PM
SALMONBUG
Status: offline
I am making some wiring
the nine chanels of the receiver are busy ... lot of wiring in this one
-throttle
-brakes
-left canard
-right canard
-gear
-emergency turbine kill
-left elevon
-right elevon
-steering
       Post #: 108
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 1:18:14 PM
jetflyer
Status: offline
Salmonbug,
Yeah I used almost every slot in my 9 channel receiver setting up my Reaper. Regarding my canard flutter, at full throttle down the runway they were flapping like a humming bird. My fourth set this time has a little less then 1/2oz of weigth in each counter balance tip. I'm hoping this might resolve my issue. It flies fine at anything below 3/4 throttle and I'm mostly using 1/4 to 1/2 during my flight.
JR
       Post #: 109
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 1:27:45 PM
SALMONBUG
Status: offline
good news, I finished the pneumatic plumbing and it keep 120 psi for 3 hours, no leaks it's always nice to know, either if you have springloaded down failsafe gear
       Post #: 110
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 5:33:01 PM
SALMONBUG
Status: offline
my battery setup is as follow
1 2400mah 7 elements for starter and pump (conected to fadec) and two 1700 mah 6 volts battery for the receiver, dual switch. One is set in the battery plug of the receiver, the other is conected to the receiver with a Y conector on one of the canard servo (I did that because I had no more free port on the receiver available.
this simple dual battery setup (using two comon switch) is recomanded on rcbatteryclinic.com and Red is a guy I thrust in
       Post #: 111
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 6:23:13 PM
DocYates
Status: offline
quote:
ORIGINAL: SALMONBUG
LOL...I hope you meant trust.
Tommy
       Post #: 112
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 6:29:57 PM
SALMONBUG
Status: offline
excuse my poor english, lol
(in reply to DocYates)
       Post #: 113
RE: MICK REEVES SUPER REAPER BUILDING - 10/26/2004 6:41:29 PM
SALMONBUG
Status: offline
My fadec is positioned in front of the tank, meaning i have extension wires on RPM and temp sensor.
the rpm sensor didn't like that and showed a residual rpm of 5000 RPM when switching on radio system . If this hapen to you, here is the solution
ferites around the wire is not a solution
a 16v 470 uF capacitor mounted in paralel with the hall sensor was the solution (this work with espiell hall effect sensor fadec, maybe not for everybody)
       Post #: 114
RE: MICK REEVES SUPER REAPER BUILDING - 10/27/2004 8:02:57 PM
SALMONBUG
Status: offline
my reaper is completed, except for some paint job on the two hatch
tomorrow, I will make a check of all the system(including turbine) in the garden.
A fellow will come with a cam, I hope to be able to show the great moment of my first jet taxi and brake test
< Message edited by SALMONBUG -- 10/27/2004 8:09:10 PM >
