cf-drg
BC, CANADA Status: offline
Looking at your photos of it in the pool, it seems to have too much wing incedence.. (the wing is at too much angle of attack)... In relation to how it is sitting on the floats.. You can lessen this by putting a 1/4-1/2" block between the rear mounting strut and the fuse... You only want about 1-2 deg. and in the photo it seems more than that.. Sounds like this model is not the best to learn float flying on. A trainer would be the best, but if you want something scale then a Cub on floats is your best bet... Don't give up though, once you get better plane,flying off water is alot of fun...
_____________________________
Darren loves floatplanes
