JimCasey
TN, USA Status: offline
Richard, I have seen Japanese websites where they appear to be flying from salt water. It can be done. Do everything you can to protect your plane from corrosion. The 4-stroke engine does not purge its bearings with fuel/oil mix as a 2-stroke does, so you should oil the crankcase breather nipple with corrosion inhibiting oil after every flying session. Mount your switch intrnally to be actuated by a pushrod, and mount all your radio equipment away from either the bottom or the top of the radio compartment so it will not get wet if there is a little water sloshing around.. We have in the US a product called "corrosion-X" that protects bearings and circuit boards from salt water. perhaps you can get that in HongKong. At least seal the wing saddle with silicone or petroleum jelly. Floats: SF (japan) Make a nice set of molded (Or "moulded" if you prefer) plastic floats. Or you can cut your own from styrofoam. Search for Randy Linderman's website for instructions. An excellent reference regardless. Go there before you buy floats.. Techniques: Amazingly similar to flying with wheels. except you have no brakes. Taxi with full UP elevator. If you chop throttle to slow idle, the plane will point into the wind. If you advance throttle 4 clicks, it should establish a steep angle on its bow wave and head off ldownwind. In between those throttle settings, you can crosswind taxi while steering with throttle, but be careful to hold the upwind wing down with aileron. The other difference from flying with wheels is that it's bloody inconvenient to walk out to retrieve your plane unless we are about to establish a religion in your name.....
_____________________________
Jim Casey/Seaplane Nerd http://www.smilesandwags.com/Floats.html
