RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box)
Page: <<   < prev  55 56 57 58 59 60 61 62 [63] 64   next >   >>
Login
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 3:09 AM
donnspadbauer
Score: 105
Last Login: 6/8/2013
Status: offline
Hey Dave, Have you ever scaled up the PBF for Gassers? I did a CIggy Pack and now I am going to try a PBF for a DLE 30. I am thinking aluminum square tube for the spine and 6mm Coro, 5/32 wire landing gear and a stearable tail wheel. Any thoughts from the PBF guru?
Hide Signatures
(in reply to Bundubasher)
       Post #: 1551
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 5:36 AM
Dave McDonald
Score: 115
Last Login: 6/19/2013
Status: offline
Never tried scaling a PBF up to gasser size.
My nephew made a foam 36x36 PBF with a .61. Flew like a kite.
A buddy made a 42x42 PBF out of 10mm coro with a .91. A bigger engine wouldn't have hurt.
Gordo made a really light foam 48x48 PBF with a .45. Flew like a kite filled with helium.
So I'm guessing somewhere between 48x48 and 60x60 would work OK for a 30cc engine. But this is just a guess.
Hint: It's much easier to cut down a too big PBF than it is to make a too small PBF bigger.
_____________________________
McDDD
ProBro 415
Hide Signatures
(in reply to donnspadbauer)
       Post #: 1552
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 9:24 AM
Bundubasher
Score: 112
Last Login: 5/4/2012
Status: offline
Donnspadbauer....hey are you going to get into the airline bussiness with that big PBF?
What are you planning to use for servo's on those large elevons?     12V wiper motors from a truck?  ,
Go for it, It will definitely be a crowd puller....
quote:
ORIGINAL: donnspadbauer
My experience is that continental drift sometimes causes the Earth to jump up and knock a plane out of the sky......
Hide Signatures
       Post #: 1553
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 9:50 AM
donnspadbauer
Score: 105
Status: offline
Hey Bundubasher, I am either going to use Hitec 5645s or 945s with a 945 for the rudder. 48" square 6mm coro and 6mm coro rudder. An all up weight of 10.5lbs 1.7 to 1 thrust to weight ratio. Hey Dave, have you ever tried a PBF that is wider than it is long? I was thinking maybe 4 X 5 to start.
Hide Signatures
       Post #: 1554
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 3:52 PM
Dave McDonald
Score: 115
Status: offline
I've never tried an out-of-square PBF, but several others on here have. They seemed to work just fine, especially if they were longer than wider.
McDDD
ProBro 415
Hide Signatures
       Post #: 1555
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/21/2010 6:01 PM
Bundubasher
Score: 112
Status: offline
Don, I've only build a 35" x 35" PBF (built it light - balsa). I was amazed at how little it took to keep it flying. Mine is battery powered and is flying with a 450 E-Flite motor - I'm going to upgrade it as it is underpowered, but flying....
I have no experience with rectangular flying objects, but I have built a lot of flying wings i.e Horten III, Nietoperz, Geier etc. - these needs a bit of washout to keep them stable. Both the Nietoperz and Horten have about 10 degrees washout on a 3m wing. I've also build various styrofoam "flying saucer (gliders) up to 1.2m diam.
 But from what I've seen with my 35" x 35" PBF and how well she handles, you should probably not have any problems. The plastic Correx may prove a bit heavy on that size PBF. A few years ago we had the "mugi craze" - those Delta slope soarers made from Correx. I've tried to build a 1.2m wingspan one but it was too heavy and because I've tried to build it light, it folded on launch.
Why not build a trial version out of styrofoam first? Lighter, easier to build, cheaper?  But I like your concept, it sure is interesting. At the size you're looking at, one can almost make a towplane for gliders out of it....
Cheers
Hey Bundubasher, I am either going to use Hitec 5645s or 945s with a 945 for the rudder. 48" square 6mm coro and 6mm coro rudder. An all up weight of 10.5lbs 1.7 to 1  to weight ratio. Hey Dave, have you ever tried a PBF that is wider than it is long? I was thinking maybe 4 X 5 to start.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1556
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/30/2010 8:52 PM
donnspadbauer
Score: 105
Status: offline
Well....... HEEEEEERRREEEEEES PIZZA! I went with a 4' long wooden stake 3/4 by 1 1/2, 4'X4' 6mm Coro and a 14" X 12" vertical stab. Servos are 200oz airtronics on the elevons and a HS 925 on the rudder. Power is a DLE 30, bateries are 2300mah 4 cell for IGN and 2500mah 6 cell for receiver. Balance was tough to get right because I wanted the engine close to the fuse and she was tail heavy. Next time I would extend the engine 3 or 4 inches and mount the control servos closer to the surfaces.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1557
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/30/2010 8:58 PM
Bundubasher
Score: 112
Status: offline
Hey, this is one serious PBF!!!... What is the AUW of it?    let us know how it flies.
Hide Signatures
       Post #: 1558
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/30/2010 9:12 PM
Goinstraightup
Score: 100
Last Login: 5/22/2013
Status: offline
That would be for an Extra Extra Large Pizza
Hide Signatures
       Post #: 1559
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/30/2010 9:15 PM
donnspadbauer
Score: 105
Status: offline
Yes Sir, I need to get a new prop and then she is gonna maiden. I will have my videographer shoot the first flight and post it ASAP. Below are a couple of pictures of Bauer Field where I fly. If there are any flyers in the Puget Sound who want to fly, just let me know.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1560
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 4/30/2010 9:20 PM
donnspadbauer
Score: 105
Status: offline
I'm going to name her "PRECIOUS"
Hide Signatures
       Post #: 1561
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/2/2010 8:15 AM
Dave McDonald
Score: 115
Status: offline
The Precious PBF looks good!
Waiting for a flight report.
McDDD
ProBro 415
Hide Signatures
       Post #: 1562
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/2/2010 3:54 PM
RC MANIAC119
Score: 100
Last Login: 6/18/2013
Status: offline
OH BABY......I CAN'T WAIT TO SEE THIS
RC MANIAC-PRO BRO 1900-AMA# 95841
Hide Signatures
(in reply to Dave McDonald)
       Post #: 1563
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/2/2010 9:15 PM
donnspadbauer
Score: 105
Status: offline
Thanks Dave, and the rest of you too, I have to get down to Valley View RC and pick my Xoar props and then she will dance!
Hide Signatures
(in reply to RC MANIAC119)
       Post #: 1564
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/9/2010 12:31 PM
donnspadbauer
Score: 105
Status: offline
Well here is the maiden. 5 minute camera timer ran out before the pogo sticking and flat spins but I will get them up soon. She flys great and has too much power........ I'm kidding... there is no such thing
http://www.youtube.com/watch?v=rJgi52PdyPA
Hide Signatures
       Post #: 1565
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/9/2010 5:20 PM
RC MANIAC119
Score: 100
Status: offline
That's pretty awesome........NICE JOB!! Looks like you're about ready to re-balance that beast..( a tad too nose heavy)..and have some real fun!!
Hide Signatures
       Post #: 1566
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/9/2010 11:07 PM
Goinstraightup
Score: 100
Status: offline
Cool!
Hide Signatures
       Post #: 1567
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/20/2010 12:21 AM
Disarray
Score: 101
Last Login: 6/11/2013
Status: offline
Thats right, I have made a proper Pizza Box Flyer:
My new pride and joy:
Hide Signatures
(in reply to Goinstraightup)
       Post #: 1568
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/20/2010 12:32 AM
donnspadbauer
Score: 105
Status: offline
Love it Man, can you get some longer axles?
Hide Signatures
(in reply to Disarray)
       Post #: 1569
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 5/20/2010 6:02 AM
Goinstraightup
Score: 100
Status: offline
Classic!!
Hide Signatures
       Post #: 1570
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 6/14/2010 1:20 AM
Bundubasher
Score: 112
Status: offline
Magnificent flying machine... hey I like that casual flick of the prop to start it...........
Enjoy
Bundu
Hide Signatures
       Post #: 1571
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 7/25/2010 8:07 PM
Clean
Score: 116
Last Login: 6/17/2013
Status: offline
Well I've finally succumbed Dave and built another PBF, the bane of every newbie that ever figured a 5 minute build to an almost indestructable airplane HAD to be the answer they were looking for. Sure, they don't have the dexterity required to use their garage door remote control but by golly they're going to fly RC airplanes if it costs them every car panel, window and neighbors dog in the area, then come ask us questions in the beginners section of every forum.
The last one, the first one, I had was back in 2002. It had a Norvel25 on mouse can. It had two throttle settings, not enough and Mach3. It wasn't much fun. This one has a TT42 and mouse with full size gear. Flew it for about an hour yesterday, got off light with only one broken prop and one replaced pull pull thread.
So, is there a 'how to fly' thread on here as indicated on your webpage or is this the combination thread which means 63 pages of reading?
As is, I'm just flying figure 8's and slowly working into higher and higher AoA with momentary hovers. Drug the tail a couple times so I'm working it down in altitude though with the limited 3D that I've flown with tuits and that GeeBeeqhor, I don't have problems figuring out it's not an airplane. Still, first flight was about 40 feet high for parts. Last flight I don't think I went over 20.
Gonna take some driveway markers out to the field to fly around instead of just figure 8's anywhere.
Required photos
Intentional landings WITH a PBF are not
the intentional design OF the PBF
Hide Signatures
       Post #: 1572
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 7/26/2010 6:39 AM
Dave McDonald
Score: 115
Status: offline
Glad to see you got another PBF going! It sounds like you were more successful this time around.
You're right, there isn't a "How To Fly A PBF" section on my web page, even though needs one. The info you're looking for is buried in the 63 pages somewhere. In the mean time, here's a few pointers about learning to fly a PBF.
1.) Don't fly too fast!
2.) Keep the nose up at a positve angle of attack. Anything less than about 15 degrees risks going too fast, and causing the nose to suddenly tuck under.
3.) Don't fly too fast!
4.) Control the airspeed with the elevator position......the altitude with the throttle......and steer it around with the rudder. If you're able to control the direction with just the aileron control, then you're probably flying too fast. (see rules 1, 3, 5, 7, 9, and 11)
5.) Don't fly too fast!
6.) The goal is to learn to coordinate the elevator and throttle to maintain a constant altitude regardless of how high the nose is aimed up.
7.) Don't fly too fast!
8.) The secondary goal is to learn to steer the PBF primarily with the rudder stick, while the aileron stick is simply used to control the wing bank angle, regardless of the rate of turn.
9.) Don't fly too fast!
10.) Read and memorize the spin recovery techniques on the web page. You're going to need them sooner or later.
11.) Don't fly too fast!
McDDD
ProBro 415
Hide Signatures
(in reply to Clean)
       Post #: 1573
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 7/26/2010 7:45 AM
Clean
Score: 116
Status: offline
Actually recovered using the outside technique twice today, then promptly DIDN'T recover from the next two inverted spins I fell into. I need to adjust the expo's on the rudder I think. I have been pretty good about just using the ailerons to hold the wings level while steering with the rudder, which is pretty much where I got into the spins. I was pretty smooth with the rons and then all of a sudden would be dipping, upping the expo took care of most of that. I think I need to do the same with the Rudder as I'm going full rudder just a little too soon when I really just need a teensy bit more rudder but I'm getting full bang.
Most off, I just need practice. The most speed I've had on it is usually just after it flips over on it's back and jams into the dirt. I did find one error. I was having a bunch of trouble adding throttle and then having it tip over on it's back. I had trimmed the silly thing for slow, level flight with the nose up. Well naturally now I have to push down in just to keep it from pitching up, or in this case back. I think I've got it pretty level now as I'm able to add quite a bit of power at neutral elevator and it doesn't pitch back. The TT 42 is really performing quite well in the throttle response, it's kinda cool to slowly come up on the power as the plane is settling and watching it slow, hold and then start climbing. Just haven't gotten to the hold it at one altitude point yet. Was a lot closer then the first flights on Wednesday though those flights were pretty much all slow speed, high Alpha level flying.
Hide Signatures
       Post #: 1574
RE: Build your own PBF (Pizza Box Flyer, Flying Pizza Box) - 7/28/2010 5:50 AM
Clean
Score: 116
Status: offline
Kay, nother question there Boss Man Dave.
Qhor with a 40fp and mouse. Would you put it on the original size one or the 40 size one?
Hide Signatures
(in reply to Clean)
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
