novabill
SC, USA Status: offline
Flew it this morning.............. PA's website says the Bad Boy is easy to hover.......Well, they are right I have'nt yet got the hovering thing down, but will get there quicker with this plane. When you put it into a hover, everything happens slower than with my other planes. This plane flys really light and has good manners. I only flew once, as the wind was already starting to gust at 7:30 am, but it was a long flight at about 15 min. I never switched on high rates, but the low rates are set at 25-30 degrees and high closer to 50. I tried some knife edge flight and it did great, hardly any rudder needed, but the wind was blowing it toward me either way I went, so I do'nt know if there will be any coupling issues. Inverted flight required only the slightest down elevator, so I am assuming I have the balance just about right. The plane does awesome tight loops and has no tendancy to snap at the top, next time I fly, I will switch on the high rates to see just how tight I can get them. Rolls are good and the ailerons are powerful in high alpha flight (something I am not too good at yet) This plane makes me look better than I am. The whole time I was assembling the plane and during the flight, I kept thinking gosh, this thing is soo light, so I took it to work with me and weighed it on a digital paint scale in the body shop. When the numbers stopped blipping around, it read 1753.5 grams. I think that comes to 61.96 ounces and 3.87 pounds. This does'nt seem possible, but the paint scale does'nt lie! 28.3 grams/oz and 16 oz/lb
_____________________________
William McClooney
