jimjel -> RE: Attn: Hobbico Elite Owners (11/16/2004 4:47:25 PM)
Geist, Re: the 864ma charge current. Are you sure the 864ma isn't the amount of charge the charger put into the batteries before it terminated charge? I only use the charger to charge Rx and Tx packs. I input the battery pack criteria and let the system pick the charge, and trickle rates. It works perfectly, takes the battery voltage about 17% above nominal voltage before peaking, then switches to the trickle rate the charger software had selected. As an example on my 1800mah NiMh 8 cell xmitter pack the software selects the following parameters: chg current .75A trickle current 40ma sensitivity 8mv/cell For my 2300mah NiMh 5 cell RX pack the software selects the following: chg current .9A trickle current 50ma sensitivity 8 mv/cell When the peak charge terminates the unit switches to trickle charge at the software selected trickle charge rate. Works perfectly every time. If you watch the display you can actually see the charge peak and the voltage start to drop. The peak charge terminates about 2 minutes after the peak is reached assuming you have an 8 mv/cell cutoff (less time with a more sensitive cutoff). I even checked the cutoff point. When the voltage drops 8mv/cell from peak the charge teminates exactly as it is supposed to. I have found the temp sensors to be very accurate as well, and they terminate the charge as they are supposed to. I haven't had any pack get over 100 degrees when charging using the software selected paramters, hence no real need for the temp sensors yet. Using the parameters assigned by the charger, I can charge 2 RX packs and 2 Xmitter packs (or any combination thereof), in an hour or less, assuming I ran my boats the previous weekend and just charge up immediately before I go boating the following week. I have had no instances of false peaking to date. No complaints here. Great little charger. Jim
