R/C-Freak
Joined: 11/24/2003 From: Apex, NC, USA Status: offline
This topic's been going a while... I have two [hopefully] quick questions, as I got my Elite a couple of days ago... I haven't found the answers here yet, but I've seen similar references... First, somebody mentioend a few pages back that their Elite doesn't trickle after a cycle.. I've noticed this of my unit, but thought I was doing something wrong. The manual says that a cycle should go to trickle at the end (and flash) but it does not... I cycled two more packs last night to verify, but sure enough, the only way I could get it to trickle was to simply do a "charge", not a "cycle"... Am I doing something wrong? This unit HAS to be able to go to tricle after a cycle... Second, after a cycle, I want to see how much was taken out.. it's handy to see how much was put in, but I consider the output to be more important... on the second to the last page in the manual, at the bottom right, it shows a picture (flowchart type) of a screen with "charge" and "discarge" capacity, but I can't actually get to that screen for some reason; I can only find the "capacity" (which I assume at that point is the charged capacity). So... any help on getting the unit to trickle after a cycle, and how to find discharged and charged capacity after a cycle? (Can you tell I've been using an AccuCyclePlus for a while?) -------------------------------------------- Burnin' up the sky... and the track...
