coomarlin
WV, USA Status: offline
I finally charged my LiPo's yesterday with the Elite. Be sure to adjust to get the correct voltage for the pack. I'm using 11.1V 3s LiPo's and I admittely used the default setting of 10.8V by accident. I thought I had the correct voltage changed, but apparently not. The accucycle offers 3.6, 7.2, and 10.8V options for LithIon cells along with 3.7, 7.4, 11.1V options for LiPo's. I should've used the setting of 11.1V but instead used 10.8. That resulted in an undercharged pack because the charger only took the pack up to 12.3V before switching to constant voltage instead of 12.6. After flying my edge I felt the batteries should've lasted a bit longer than they did. I will retry charging the packs at 11.1 and see what kind of difference it makes in terms of flight duration. I didn't time it but I think I got about 12 minutes out of my 850mah pack before.
_____________________________
Windy Ridge RC Club
