RE: Attn: Hobbico Elite Owners
Tower Hobbies
Logged in as Guest
  Printable Version
Tilt-A-Whirl Helicopter Workstand
Seller:  Prontow
Details:   $175.00   |  10/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: Attn: Hobbico Elite Owners
Page: <<   < prev  3 4 5 6 7 [8] 9 10 11 12   next >   >>
Login
RE: Attn: Hobbico Elite Owners - 9/24/2004 12:00:11 AM
Geistware
Status: offline
Have you purchased a unit?
I finally got my replacement after frying it.
What I found out is that the original one still worked.
It is a very robust charger.
quote:
ORIGINAL: K_White
Thanks guys, this thread has been very helpful.....Keep it up!!!!!
_____________________________
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to K_White)
       Post #: 176
RE: Attn: Hobbico Elite Owners - 9/25/2004 4:23:16 AM
K_White
Status: offline
Yeah, I bought the Elite this week and love it!
(in reply to Geistware)
       Post #: 177
RE: Attn: Hobbico Elite Owners - 9/25/2004 9:35:01 PM
JoeAirPort
Status: offline
I've been using this charger for a while now with no problems at all. It's exactly what I needed. Now I get to use it to charge Lipoly's on my Shockflyer 330S.
       Post #: 178
RE: Attn: Hobbico Elite Owners - 9/26/2004 8:48:57 PM
Geistware
Status: offline
I am planning on getting a Shockflyer or a Raptor. Let me know how it works with Lipos!
quote:
ORIGINAL: JoeAirPort
(in reply to JoeAirPort)
       Post #: 179
RE: Attn: Hobbico Elite Owners - 9/27/2004 3:59:48 AM
Dan767
Status: offline
Geistware,
I've used my Elite on my Li-Po's for my Shock Flyer. Previously, I used my Apache (www.anyrc.com) to charge them. The Apache charged my Kokam 700ma 2cell in 35-40 minutes. First attempt using the Elite took 2hrs at the default setting. I didn't get quite the run time with the first charge either. Try charging as close to the max charge rate for the cell(s) you use, for a quicker charge and possibly longer run times.
Dan
www.ctf.org www.caringbridge.org/visit/ashleyv Isaiah 40:31
       Post #: 180
RE: Attn: Hobbico Elite Owners - 9/27/2004 11:16:47 AM
Geistware
Status: offline
Dan767
DO you know why it took longer?
Could you try it a couple of more times to see if you can figure out why?
THe first charge may be with a dead pack and the later chargers may be with a pack that has some juice in it.
(in reply to Dan767)
       Post #: 181
RE: Attn: Hobbico Elite Owners - 9/27/2004 11:38:38 AM
coomarlin
Status: offline
With a charge rate of 1C my Elite charges my 850mah 3s Lipo's in 1 hour 12 minutes. Almost like clockwork. Those are fully drained batteries down to 3.0V/cell.
Windy Ridge RC Club
       Post #: 182
RE: Attn: Hobbico Elite Owners - 9/27/2004 4:03:55 PM
Geistware
Status: offline
Thanks coomarlin
SO when you fly on electric, you always have a pack on charge to get more flight itme or what?
(in reply to coomarlin)
       Post #: 183
RE: Attn: Hobbico Elite Owners - 9/27/2004 8:15:17 PM
Dan767
Status: offline
Geistware,
Charged the pack today. Took 71:54minutes and 377ma. at the 1C rate. It had been sitting in a discharged state for two weeks. Quick review: AXI 2208/34 on my Shockflyer. Kokam 700mah battery, Phoenix 10 controller. I have an extra Phoenix 10 controller if your interested that I have never used.
Dan
       Post #: 184
RE: Attn: Hobbico Elite Owners - 9/27/2004 11:08:54 PM
Geistware
Status: offline
Did a quick check and found that at 300ma and 1.1 volt cut off, my 2700maH NiMH pack has a consistant 2550maH capacity. At 1 amp, the pack can deliver it for only 1600maH of charge.
I then tried my 1650maH pack and at 300ma and 1.1 volt cut off it shows 1500maH but at a 1 amp load, it only has 915maH of capacity. I may plan to try this with NiCads and see what happens. This is with 5 cycles and I got consistant readings from the 2nd through the 5th cycle. The first cycle always showed a higher capacity.
       Post #: 185
RE: Attn: Hobbico Elite Owners - 9/28/2004 2:48:19 PM
coomarlin
Status: offline
quote:
ORIGINAL: Dan767
Geistware,
Charged the pack today. Took 71:54minutes and 377ma. at the 1C rate. .
That pretty much jives exactly with what I stated in my above post. 1 hour 12 minutes.
Geist, I have 2 battery packs and can get about 15-20 minutes of flight per pack. I normally always rest my neck for 15-30 minutes after each flight so I always have a fresh pack available when I need it. It would be a waste fo rme to buy a 3rd pack right now because the others charge fast enough that I don't need one.
Windy Ridge RC Club
       Post #: 186
RE: Attn: Hobbico Elite Owners - 9/29/2004 3:26:53 AM
David_Moen
Status: offline
I'm seeing the same sort of thing with my Elite. I have a 1700 ma 4 cell NiCD pack on my RX, if I cycle it with my Elite, it consistantly indicates a capacity of 1430 to 1440 ma. I'm charging using all the settings that the charger figures out. I've tried reducing the charge rate by 50% so that it takes longer to charge, I've heard that this will allow the battery to store more engergy.
I was thinking of sending my packs back to my supplier thinking that they were bad.
Oddly, when I charge the 8 cell 1800 ma pack my son has for his truck, it charges to about 2100 ma.
What can I change to get more juice into my batteries?
I also figgered out that the unit does not trickle charge after a cycle, only after a peak charge.
David Moen
www.mvvs-canada.com
       Post #: 187
RE: Attn: Hobbico Elite Owners - 10/2/2004 1:25:11 AM
Geistware
Status: offline
David, what I am seeing is that I am testing the pack at my plane's equivelent load. When you test a pack, you should discharge it to 1.0 or 0.9 volts per cell at a rate of 300ma. This is comparable to how the manufacturer tested the cells. This will show a higher capacity.
After cycling my packs 5 times I see that I should get 1400mah out of a 2700maH NiMH pack with a 1 amp load. This should be equal to 1.5 hours of flying time. Today, I put 9 10 minute flights on my plane. That is 1.5 hours and my 5 cell pack read 6.15 volts. For me the charger provides a real world measure of my packs capability. I just wish it would charge two packs with a common ground.
quote:
ORIGINAL: David_Moen
(in reply to David_Moen)
       Post #: 188
RE: Attn: Hobbico Elite Owners - 10/2/2004 1:33:51 AM
BasinBum
Status: offline
quote:
ORIGINAL: Geistware
snip......After cycling my packs 5 times I see that I should get 1400mah out of a 2700maH NiMH pack with a 1 amp load. ....snip
I'm confused. Shouldn't you get 2700 out of a 2700 pack regardless of what the discharge rate is?
Has anyone tested the stated discharge rate against a meter as well as the cutoff voltage to see how well calibrated these are?
