B25 Documentation    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> B25 Documentation
Page: [1]
Login
B25 Documentation - 6/20/2004 10:13 AM
Peter G.
Score: 100
Last Login: 9/13/2012
Status: offline
Can anyone point me to an internet site that has documentaion such as missions etc. on a B25 called the Executive Sweet.
Thanks in advance Peter.
Hide Signatures
       Post #: 1
RE: B25 Documentation - 6/17/2005 8:03 AM
crashchamp1
Score: 100
Last Login: 9/6/2007
Status: offline
I was researching for my B-25 and found this web site with loads of info, http://www.b25.net/
Hide Signatures
(in reply to Peter G.)
       Post #: 2
RE: B25 Documentation - 6/17/2005 8:21 PM
clscale-RCU
Score: 100
Last Login: 2/1/2013
Status: offline
That B-25 is still flying today and www.bobsairdoc.com has pictures if you need that. The restored aircraft has probably changed slightly over the years so be sure the pictures are all taken in the same time frame.
_____________________________
Fred Cronenwett
Float flying and scale
Hide Signatures
(in reply to crashchamp1)
       Post #: 3
RE: B25 Documentation - 6/18/2005 3:38 AM
the-plumber
Score: 104
Last Login: 8/15/2006
Status: offline
Dunno that 'Executive Sweet' has a war record to speak of, being a TB-25N.
Look up N30801 in the aircraft registry at www.faa.gov and contact the present owners.
Cheers,
Fred McClellan
Hide Signatures
       Post #: 4
RE: B25 Documentation - 6/18/2005 5:01 AM
crashchamp1
Score: 100
Status: offline
Thanks, Fred
Hide Signatures
(in reply to clscale-RCU)
       Post #: 5
RE: B25 Documentation - 10/26/2011 9:30 AM
skubacb
Score: 100
Last Login: 3/11/2013
Status: offline
I know this is a really old thread but:
I cannot find documentation which includes the nomenclature for access panels and doors. I.E. I can get the info on the bigger stuff. But I would like the lettering for access panels, electrical panels, oil ports etc. Any lettering that was on the outside of the B-25.
Any help out there?
Cheers,
Craig
Hide Signatures
       Post #: 6
RE: B25 Documentation - 10/26/2011 6:31 PM
rcphotog
Score: 110
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: skubacb
Any help out there?
Just a suggestion. You might look at one of the better detailed plastic models in 1:48 scale or larger if available. Thirty years ago when I did all of my plastic model building, there were some pretty detailed models and decal sheets available. As I recall there was a company called Microset ? that produced decal sheets sold seperately for 1:72, 1:48, 1:32 etc...
These decal sheets included so much in way of the tiny details you speak of. Plastic model kits are an invaluable resource for the scale R/C builder as all of the research is done for you. You can also see what the surface details look like ie; panel lines, rivet and fastener, fabric, antennia location and gear details like brake lines.
Regards,
Ken.
~kensaeroden.com~
Producer of model airplane calendars~"Masters of SCALE R/C" new for 2013
Hide Signatures
(in reply to skubacb)
       Post #: 7
RE: B25 Documentation - 10/27/2011 8:15 AM
skubacb
Score: 100
Status: offline
Good idea and I will look again.
I did a search for the full size plane and unknown to me I live only 10 miles away from one. I didn't think the Pima air museum had a B-25 but they do. Now the question is what shape is it in, are all the details there, and can I get close enough to photograph.
Would much prefer something like you suggested or some done with a really sharp expensive camera.
Cheers,
Craig
Hide Signatures
(in reply to rcphotog)
       Post #: 8
RE: B25 Documentation - 10/27/2011 9:35 AM
Avaiojet
Score: 111
Last Login: 5/26/2013
Status: offline
Peter,
This link will help you along your way.
http://www.vg-photo.com/bombers/b25misc.html
What is the size of your model? I'm sure I can help you with some of your needed lettering for it.
Charles
Charles, owner, CFC Graphics, Vinyl graphics "Model Airplane Graphics from a Model Airplane Builder." 58 years of modeling.
Hide Signatures
       Post #: 9
RE: B25 Documentation - 10/28/2011 10:54 PM
skubacb
Score: 100
Status: offline
Hi,
Thanks for that. I am a little nuts on this. The plane is the Top Flite model so it is only 1/9 scale. So the lettering that I want to do is all the very small stuff. In those pictures you can see some of the bigger lettering just below the cockpit. The B-25 has more lettering on small hatches, electrical access, oil fill, etc.
Funny thing is that the small Top Flite P-51 comes with much of this lettering in their decal package but then doesn't specify where is is to be placed.
For the small stuff I am going to do my own water slide decals since this lettering really needs to lay down on the surface.
When it is all done I will clear coat the entire plane.
Cheers,
Craig
Hide Signatures
(in reply to Avaiojet)
       Post #: 10
RE: B25 Documentation - 11/3/2011 3:22 PM
Fill
Score: 100
Last Login: 7/27/2012
Status: offline
This doesn't directly answer your question.
But here's a really nice link to all kinds of info on the 25 right here on this sub channel
http://www.rcuniverse.com/forum/m_6274723/mpage_6/key_/tm.htm
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
