WILDGAS
FL, USA Status: offline
quote:
ORIGINAL: KatanaMadMan Hi Guys, Here's some pics of my CM pro Zero. Same as GSP. I have a 31cc Ryobi conversion in mine. Flys very well at just over half throttle. These are great value for money, nicely finished. Pity the paint tends to chip off of you knock it though. I'm running a 16 * 10 3 blade MA prop, taching at 7600. Pushes about 13-14 lbs on a fish scale. Plenty for the Zero. Have about 30-40 flights on her now. Had to put Robart airs in on the retracts. Had mechanicals for a while but the servo just couldn't handle it. One thing you need to look at is the retract rails in the wing. There's just no glue holding them in. Reinforce them with some epoxy or similar. Both mine broke out on initial flights with reasonable landings. They weren't perfect but I wouldn't have expected to see the complete retract break out. The other thing is the push rods to the elevator and rudder. They need to be encapsulated somewhere in the centre section of the rear fuselage to stop the rods from being able to move sideways. My friends CM pro Spitfire ended up with flutter on the elevator due to the sideways movement, which broke the servo arm, the plane ending up in a screaming heap. Not pretty. Anyway hope you like the pics. KATANAMadMan, I have the same engine, and I'll buy the same Zero hehehehehehehe. Could you post more picture of your zero, and if you have a video, I would like to see it.
_____________________________
Thanks a lot, Carlos
