Castor Amount in Fuel
Tower Hobbies
Logged in as Guest
  Printable Version
Used Quadra 35 with Spring Starter and Muffler - RTF
Seller:  gdeezer
Details:   $140.00   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Castor Amount in Fuel
Page: [1]
Login
Castor Amount in Fuel - 6/23/2004 3:20:44 PM
obolel
Status: offline
I was running %15 pure castor and %85 methanol, and my engines are performing excellent ( except YS, itreally needs nitro ). I am planning to reduce castor content to %10, does anybody tried this ? Although it seems low, I think excellent properties of castor oil will be enough even in that percentage mix.
Looking forward for your comments,
Thanks.
       Post #: 1
RE: Castor Amount in Fuel - 6/23/2004 4:31:20 PM
Sport_Pilot
Status: offline
Maybe. Could be an expensive experment too. Let us know how it works out.
(in reply to obolel)
       Post #: 2
RE: Castor Amount in Fuel - 6/24/2004 4:04:47 AM
downunder
Status: offline
Before you do that, get a thermocouple (not the infra red type) so you can keep track of head temps with the different oil contents. Personally I'd start with 20% castor and use that as a base line. You'd need to mix small batches of fuels so you can quickly do back to back runs.
(in reply to Sport_Pilot)
       Post #: 3
RE: Castor Amount in Fuel - 7/2/2004 7:36:32 PM
Bax
Status: offline
You might also want to consider that as the oil percentage gets lower, you have less and less margin against a lean run, which can easily happen in an airplane...especially as the fuel tank gets low and you pull high-G maneuvers. The lower the safety marging, the more chance of engine damage.
Also, extra oil is a help in cooling. Heating something and then throwing it away means the heat goes with it. If your engine is assured of a constant fuel flow, then you can probably lower the oil content a bit. Only 10% oil content would likely be too low for most model two-stroke engines.
bax
(in reply to downunder)
       Post #: 4
RE: Castor Amount in Fuel - 7/2/2004 7:38:12 PM
Bax
Status: offline
We once ran a ducted-fan engine on 18% oil content fuel and had it immediatly seize the connecting rod to the crankshaft due to a lack of lubrication. Going to 23% oil content solved the problem. The two fuels, 18% and 23%, had the same oil blend, just different volumes per gallon.
bax
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.766RCU1
