the Swamp Fox
SC, USA Status: offline
quote:
But be aware of its tendancy to stall and tumble without warning if you suddenly pull on full "up" elevator for a high alpha nose angle, while the model is travelling at high speed Hmm..I've yet to see this with the MiG .Not saying it won't happen or it could be forced to do so. Whenever I pull up hard you can watch the anhedral flex out and up she goes . same when rolling to invert and pushing up stick for a nice ,steep climb-out. If you don't come into that one with enough speed it will snap a little at the top,drop a wing and recover pretty easily as it begins to dive. The MiG V-stab / h-stab/elevator arrangement is quite different than the 183. In any event, you maiden yet , John ? G'luck all
