RE: Alfa Model Mig 15
Tower Hobbies
Logged in as Guest
  Printable Version
EASYTIGER'S Mirage IIIC VERY HIGH PERFORMANCE ONLY $129!
Seller:  EASYTIGER
Details:   $129.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Alfa Model Mig 15
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Alfa Model Mig 15 - 11/23/2004 5:32:31 PM
the Swamp Fox
Status: offline
good luck with the Panther...didn't look too slow to me !
loved the way it rolled.
Aiken huh?
that's only a couple hours away , a freind that lives down here on the coast is from there.
be sure to post impressions and pics of the panther once ya get it !!!
best of luck !
(in reply to Woody 51)
       Post #: 101
RE: Alfa Model Mig 15 - 11/26/2004 10:51:44 PM
Woody 51
Status: offline
Swampy.
Are you down Charleston way?
_____________________________
A crash keeps one's opinion of one's flying ability, in perspective.
(in reply to the Swamp Fox)
       Post #: 102
RE: Alfa Model Mig 15 - 11/28/2004 11:22:12 PM
the Swamp Fox
Status: offline
That's affirmative Woody,
'bout 15 mins south of Charleston
seen the F-104 Starfighter vids ?
take care
       Post #: 103
RE: Alfa Model Mig 15 - 11/29/2004 4:08:05 PM
blue action
Status: offline
Hi there, sorry for interrupting, I hope this is the right place to post a question about the EDF assembly for the Alfa Mig15.
I have just finished the assembly of the EDF power unit with the MJ 25-26 Mk2 motor and hooked it up. Nice thrust, I can blow a door open from 5ft away
Regarding the vibrations, how can you tell if the vibrations are 'good' or 'too much'? The instructions tell you to be very prudent with balancing the aluminium plug, adjusting the fan etc. to remove vibrations to improve performance and life time of engine bearings. Well I can tell you the thing is screaming (seems to have the same aggressive sound as on Andy Steere's videos) and after a couple of minutes holding the fan in my hands at 50-70% thrust my hand feels kinda numb and shaky. I guess there are some vibrations, but hey the thing is spinning at 30-40000 rpm so what do you expect.
So here's my question. Would you guys recommend to disassemble the whole thing and do more balancing to try to eliminate the vibes? I can't get the fan off easily any more as the screw holding it won't come off (it turns the aluminium plug and motor shaft and I can't hold it).
Another question regarding wing gluing. My packet came without that 'UHU' but only 5min epoxy. Will it be OK to glue everything (also wings) with the epoxy? (sanding and poking surface areas)?
Thanks!!
       Post #: 104
RE: Alfa Model Mig 15 - 11/30/2004 2:44:30 AM
the Swamp Fox
Status: offline
Hi Blue,
If you read alfa power instruction section . It will tell you there will be an rpm range where vibration will occur . Advance throttle rapidly through those ranges. Mine vibrates @ a little more than 1/2 throttle so I don't fly there. If it vibrates throughout the entire throttle range, someting is out of balance.
Don't use 5 min epoxy...go for the slow cure or probond....it's stonger
sand the root, poke MANY holes through the fuse...allow the epoxy to seep inside the fuse...I then laid up .75oz glass to soak it up and add a little strength..so far so good
Apologies, we were drifting a bit off topic as noone was really posting on the mig
MiG 15 sortie#72 complete
best of luck .
(in reply to blue action)
       Post #: 105
RE: Alfa Model Mig 15 - 11/30/2004 3:33:36 AM
blue action
Status: offline
Swamp, the vibrations don't change with throttle setting, pretty consistent across the whole RPM range (except very low power). But I played around a little more with it, and to my surprise when I take off the 'spinner' snap-on cap the vibrations are almost completely gone. I guess I'll start experimenting with putting a little tape inside the spinner like somebody else suggested on 'the other forum'. I'm just glad I don't have to take off the whole fan (that would be a mess as the screw won't open).
Thanks for the tip with the slow-cure. Will use my 30 min epoxy leftovers from the last 'hard landing' with my hotliner. I'll also put it some clothes inside the fuse in the area where the wings attach.
Will keep you posted!
       Post #: 106
RE: Alfa Model Mig 15 - 11/30/2004 12:03:25 PM
Woody 51
Status: offline
Blue, a little Great Planes Milled Fiberglass mixed into your epoxy is also a good alternative.
Re vibrations. All turbines have what is knows a "Critical Speed" range. Swampy is right in that you must get them through it as quickly as possible, though it sounds like the end cap on yours is out of wack.
Swampy, I used to work for a Charleston Company. Love the city. Hope to get back there for a "look see" in about 12 months or so.
< Message edited by Woody 51 -- 11/30/2004 12:06:40 PM >
       Post #: 107
RE: Alfa Model Mig 15 - 12/1/2004 4:31:05 PM
blue action
Status: offline
Found a solution to the vibrations induced by the spinner: put it flat on the table and noticed it tilted quite a bit to one side. Put a couple of medium sized drops epoxy inside the spinner to the lighter side and let it dry. Repeated process until it was balanced and stood upright on the table (on its tip). NOW we're talking! Runs very smooth now, and I have not found any 'critical RPM range' so far. Could not resist to use the fan to fire up my bbq last night- those pork chops were done in no-time . (After all these EDF tests my 1-year old son starts imitating that noise all the time- mmmmmmmmhh)
Also removed the paint from the fuse where the wings attach with a sharp knife. Have blank styro now where the glue will go (punctured too). Unfortunately I cut into the surface a little to deep at one point so there's only ~2mm material left in an ~.5 inch long area somewhere in the forward third of the wing attach area . But I am planning to put some epoxy soaked glass cloth inside the fuse in that area, so it should not matter. I hope.
Need to find a quiet hour one of these nights to glue the wings on. Will keep you posted.
       Post #: 108
RE: Alfa Model Mig 15 - 12/1/2004 10:40:30 PM
Loopman
Status: offline
Is there an alternative motor to the MP Jet 25/25-26 as Hobby Lobby is out until the end of January!
Loopman
(in reply to nitroshark)
       Post #: 109
RE: Alfa Model Mig 15 - 12/2/2004 12:40:40 AM
wekenav8r
Status: offline
If you don't mind spending an extra $10, check and see if they have the motor with the gearbox in stock. I did this a couple months ago when they were out of stock on the MPJ motor. Then just pry off the pinion gear and take off the gearbox and you're ready to drop it in the fan. It's the same motor, just comes with a reduction gearbox installed.
Tim
(in reply to Loopman)
       Post #: 110
RE: Alfa Model Mig 15 - 12/2/2004 11:15:23 AM
Woody 51
Status: offline
Try AIRCRAFT at
http://www.aircraft-world.com/shopexd.asp?id=2032
They've got 'em at $50.95 plus postage. Even thought they are in Japan, postage to the US is extremely cheap and delivery takes about 4 days from payment.
They take PAYPAL.
I get a lot of my elect R/C stuff from them. Service is great and they are very reliable.
       Post #: 111
RE: Alfa Model Mig 15 - 12/2/2004 4:19:42 PM
Loopman
Status: offline
Hey Fellas,
Thanks for the advice on a substitute motor! I ended up ordering a HiMax 2015-4100 and am eagerly looking forward to getting this "communist comet" in the air! I am also going to try using an HS-81 servo for the ailerons, it's a little heftier on torque than the HS 55's.
Happy Flying!
Loopman
       Post #: 112
RE: Alfa Model Mig 15 - 12/2/2004 9:11:57 PM
Woody 51
Status: offline
Hi Loopman,
The Himax will run quite hot inside the ALFA fan unit shroud.
Suggest you look at the mods that ANDY STEER has done to his (and posted on the internet,) to to help alleviate the heat problem.
See:http://astro.umsystem.edu/andy/rc/mig15/
and go right through the site.
N.B. The recommended MPJET motor also gets hot, so don't worry that you've may be purhased a problem.
Let us know how your bird flies. It's always good to get feedback, we're all interested.
Good Luck.
       Post #: 113
RE: Alfa Model Mig 15 - 12/2/2004 11:28:08 PM
Loopman
Status: offline
Yep! I have gone through Andy's site and even saved it as one of my favorite places. The shroud without a doubt needs some cooling flow through! I will keep everyone posted on how it all comes out.
Happy Flying!
Loopman
