ImRich
NH, USA Status: offline
Myron, Patrick, Yes, that is correct. When we registered rcapa.org we only looked at what .ORG domains were available. We were not interested in .com, .net, .us, .biz or any other tld, but we wanted to restrict our search to .org. Why is that so hard to understand? This happened while I was talking with another member when we were discussing how people tend to think that we are a heli only oriented group because of our domain name. While we were talking we were trying different domain names in the .ORG tld and found that RCAPA.org was available, so I registered it as it was available at the time. The thought process was that the terms 'remote', 'remote control' and 'RC' are often used interchangeably so that rcapa.org would be a good alternative to helicam.org for the Remote Aerial Photography Association and would better represent the fact that we were not oriented toward any particular aerial platform. The Remote Aerial Photography Association is the name of the organization, not helicam.org or rcapa.org, those are simply domain names which point to the RAPA web site. This is no different than the Academy of Model Aeronautics using the domain name modelaviation.org, sometimes you simply can't get a domain name that matches the acronym for your organization. You keep mentioning that you checked the domain name registration dates as an example as to the creation date of RAPA. Please be sure to check helicam.org as this was the domain name the Remote Aerial Photography Association was using from the beginning. We later picked up rcapa.org as explained above. As we are a growing young organization we did not start with a domain name that exactly matches our organization name, but did the best we could considering the circumstances. A lot of groups have domain names that do not match exactly their full entity name and have alternate domain names which also lead to the main web site. Everything the RAPA group has done has been to try to promote commercial/professional remote (or if you prefer remote control) aerial photography without regard to aerial platform. I honestly believe that the best thing would be for us to find a way to work together. As I explained to Rick, when we created the Remote Aerial Photography Association, we had no knowledge of any other group. You have all seen the naming threads on the RR forum so you know how o |
