RE: New Sig Sun Dancer Bipe!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: New Sig Sun Dancer Bipe!
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: New Sig Sun Dancer Bipe! - 12/14/2004 3:29 AM
dannafinance
Score: 100
Last Login: 2/9/2013
Status: offline
I guess I will not be able to upload the manual after all. I have it in PDF format if someone would like to see it. If someone could give me some advise on the upload I will do it. It appears that RCU only supports jpeg, txt, gif and not pdf. Send email to bmyers@koyote.com and I will be glad to pass it along.
Hide Signatures
(in reply to Geistware)
       Post #: 101
RE: New Sig Sun Dancer Bipe! - 12/16/2004 10:56 AM
Tony Flores
Score: 100
Last Login: 6/19/2013
Status: offline
Blue Ice,
Did you come up with a muffler for your DA50 that did not require cutting the side of the cowl?
Hide Signatures
(in reply to blue ice)
       Post #: 102
RE: New Sig Sun Dancer Bipe! - 12/16/2004 12:52 PM
blue ice
Score: 100
Last Login: 6/30/2009
Status: offline
Tony,
Have not ordered engine or muffler yet. Been working to many hours. I plan on working on plane over the holidays. I did see Sig's Sun Dancer at a expo in Chicago. It had the F.P.E. on it and they did not have to butcher the cowl.
Hide Signatures
(in reply to Tony Flores)
       Post #: 103
RE: New Sig Sun Dancer Bipe! - 12/16/2004 9:06 PM
Tony Flores
Score: 100
Status: offline
Blue Ice,
Thanks for the response. I have A DA50 I had planned on using for this plane. I don't like having to butcher the cowl so I may have to use the FPE 3,2 instead.
Regards
Tony
Hide Signatures
       Post #: 104
RE: New Sig Sun Dancer Bipe! - 12/17/2004 2:28 PM
Geistware
Score: 100
Last Login: 5/2/2008
Status: offline
Is the manual online someplace.
I want to see that before ordering one.
quote:
ORIGINAL: dannafinance
I am going to try to upload the manual. This one great ARF.
_____________________________
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
Hide Signatures
(in reply to dannafinance)
       Post #: 105
RE: New Sig Sun Dancer Bipe! - 12/18/2004 1:26 AM
dannafinance
Score: 100
Status: offline
No, the manual is not online. I could not get it to up load. I can email you one if you will send your email address. bmyers@koyote.com
Hide Signatures
       Post #: 106
RE: New Sig Sun Dancer Bipe! - 12/22/2004 10:53 PM
dannafinance
Score: 100
Status: offline
Has anyone used the Hitec servos with Karbonite gears? I am having touble finding Metal Gear servos close to home. I found servos with Karbonite, but am unsure about using them. I might have to order metal gear if karbonite will not work. I will have to wait a feww days to get them.
Hide Signatures
       Post #: 107
RE: New Sig Sun Dancer Bipe! - 12/23/2004 2:22 AM
SunShyne
Score: 120
Last Login: 6/11/2013
Status: offline
send it ot me via email to v12kid@gmail.com and I can load it up on my website for all to share if you would like
matt
Revver Bro #86
Visit RCU''s E-flight Only Website: www.WattFlyer.com
Hide Signatures
       Post #: 108
RE: New Sig Sun Dancer Bipe! - 12/23/2004 3:21 AM
dannafinance
Score: 100
Status: offline
I tried to email it to you. It is a pretty big file. Let me know if you get it.
Hide Signatures
(in reply to SunShyne)
       Post #: 109
RE: New Sig Sun Dancer Bipe! - 1/1/2005 12:13 AM
leblanc
Score: 100
Last Login: 3/8/2009
Status: offline
rc4fun will the sun dancer have 3d performance with teh 2.4 c. in. first place engine or will it laack of power.
I am wanting for a vertical climb doesn't have to be fast just be able to climb.
LeBlanc
Hide Signatures
       Post #: 110
RE: New Sig Sun Dancer Bipe! - 1/1/2005 3:51 AM
rc4fun
Score: 100
Last Login: 5/29/2009
Status: offline
leblanc,
The FPE 2.4 won't have enough power for 3D. I'd stick with a 3.2 (50cc).
rc4fun
Hide Signatures
(in reply to leblanc)
       Post #: 111
RE: New Sig Sun Dancer Bipe! - 1/4/2005 12:51 AM
leblanc
Score: 100
Status: offline
Is it possible to start a G-62 without a electric starter? I've heard that you need a little bit of speed to start an engine with a magneto instead of a electric thing. Will I be able to start it with my hand or it's just impossible is my question?
LeBlanc
Hide Signatures
(in reply to rc4fun)
       Post #: 112
RE: New Sig Sun Dancer Bipe! - 1/4/2005 1:18 AM
chuck l
Score: 108
Last Login: 6/18/2013
Status: offline
leblanc,
Yes, you can start a G62 by hand, you just have to now where to set the prop relative to the flywheel and wack it a good one. The manual shows the position. With that said, it is much safer to do it with a starter. I bought a Sears 19.2 volt cordless drill and a large cone driver from Tower Hobby, works fine. You will need to put a bolt through the hole on the cone driver to chuck it up in the drill. The drill can drill 3" deck screws well into a board.
Chuck
WACO Brother #233
Hide Signatures
       Post #: 113
RE: New Sig Sun Dancer Bipe! - 1/4/2005 1:43 AM
leblanc
Score: 100
Status: offline
Thanks chuck that saves loads of money!!
LeBlanc
Hide Signatures
(in reply to chuck l)
       Post #: 114
RE: New Sig Sun Dancer Bipe! - 1/4/2005 5:30 AM
blue ice
Score: 100
Status: offline
I just got off the phone with Bill at Taurus Engines. I ordered a TS52 from him for my Sun Dancer. Now I have to wait till the middle of the month for him to ship it because he is going out of town to a big event in Canada.
Hide Signatures
       Post #: 115
RE: New Sig Sun Dancer Bipe! - 1/16/2005 8:43 PM
dannafinance
Score: 100
Status: offline
I am getting ready to check the incidence on the top wing. Any suggestion? The manual says to zero it out. I have been advised that it is best to set the top wing at -1. Suggestions would be welcome.
Hide Signatures
       Post #: 116
RE: New Sig Sun Dancer Bipe! - 1/17/2005 2:57 AM
rc4fun
Score: 100
Status: offline
I set mine at 0 degrees and have had no problems.
Hide Signatures
       Post #: 117
RE: New Sig Sun Dancer Bipe! - 1/20/2005 8:51 AM
leblanc
Score: 100
Status: offline
rc4fun
I ve recently heard about ZDZ engines. Will the 40cc RE have enough for 3d? It has .05 more horsepower than the g-62. Static thrust is rated at 25.79lbs and it weighs 3.15 lbs with the ignition.
LeBlanc
Sorry if i am getting a little enoying
Hide Signatures
       Post #: 118
RE: New Sig Sun Dancer Bipe! - 1/20/2005 10:23 AM
Hans Meij
Score: 100
Status: offline
quote:
ORIGINAL: leblanc
At 9000 rpm with a 18*8 prop it will have 5Hp, but not with a prop suited for this model.
Mine did only 7200 rpm on a 19*10 with a Krumscheid pipe.
Performance figures for the ZDZ40 from the manufacturer are a bit exaggerated I think.
If you want 3D with a model of this weight you need a engine with more cc's
Hide Signatures
       Post #: 119
RE: New Sig Sun Dancer Bipe! - 1/20/2005 8:04 PM
rc4fun
Score: 100
Status: offline
LeBlanc,
I agree with Hans. You are going to need a good, strong, lightweight engine in the 50 cc (3.2 ci) range for the best performance. You're just going to have to dig into your wallet and get a DA-50, FPE 3.2, Brison 3.2, BME 3.2 or something in that class and price range.
rc4fun
Hide Signatures
       Post #: 120
RE: New Sig Sun Dancer Bipe! - 1/21/2005 5:03 AM
leblanc
Score: 100
Status: offline
rc4fun ya i found that for 52$ more i can get a 3.2 brison for only 612$ canadian which is 495$ dollars for you.
So how is your sun dancer going still flying?
LeBlanc
Hide Signatures
       Post #: 121
RE: New Sig Sun Dancer Bipe! - 1/21/2005 5:24 AM
rc4fun
Score: 100
Status: offline
LeBlanc,
Still flying great. Best plane I've ever owned!! Weather's been pretty nasty here for the last three weeks with low clouds and fog. I haven't flown the Sun Dancer during the bad weather spell because the clouds and fog take the fun out of using smoke!! So, I've been flying electric foamies. You can keep them low and close. Lots of cheap 3D fun. and they don't take a ton of equipment to get them in the air.
Tom
Hide Signatures
       Post #: 122
RE: New Sig Sun Dancer Bipe! - 1/29/2005 1:19 PM
blue ice
Score: 100
Status: offline
Tom, I just got my Taurus engine in the mail today. I see what you mean about the pitts muffler interfering with the firewall. I will have to get together will Bill at Taurus and a very experienced builder friend of mine to overcome the problem. What I wanted to ask you was did you put any right thrust in when mounting your engine? Manual does not state any. I am going to have my standoffs made and should take this into account now. Thanks for your reply ahead of time.
Jeff
Hide Signatures
       Post #: 123
RE: New Sig Sun Dancer Bipe! - 1/29/2005 5:16 PM
dannafinance
Score: 100
Status: offline
The Sun Dancer has thrust built into to it. I think there is about 2 degrees already there.
Hide Signatures
       Post #: 124
RE: New Sig Sun Dancer Bipe! - 1/29/2005 5:48 PM
SitNFly
Score: 100
Status: offline
Anybody know if the manual has been posted anywhere yet? There were some rumblings about it earlier in this thread, but haven't heard if it actually was posted.
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
