Allie33
FL, USA Status: offline
Well thanks for all the input. First I must correct the starting voltage figure. It was 4.7 volts NOT 4.9, I sorry that I mislead you with that figure. And yes, it was charged on the NiMH setting using a 12Volt booster pac as I drove to the field, less than 30 minutes. As I see it, here is what I think happaned. The end cell shorted internally. It got hot enough to melt the heat shrink and melt the solder on the tab of that cell only. That cell has zero volts and 0.4 Ohms resistance and the other 3 cells, appximatel 1.4 Volts. I can't blame this on the MK2 charger but that shorted cell sure looks suspicious . What do you think?quote:
ORIGINAL: Allie33 Well: I charged my 2 year old 1400 MA nimh pack at the recommended max rate of 1.0A on my Hobbico MK 2 field charger. Starting voltage was 4.9 V. Voltages after meltdown are: Burned cell 0.0v 1.21 1.26 1.27volts, Looks like a shorted cell to me. What do you think? I well try to connect photographs.
